How Do I Put On My Foam Grips
Dave Sutton
I have just bought some foam grips. Can somebody tell me what i need to put with them to make them stick just as good as using Hairspray with rubber ones.
My friend turned his inside out, used hairspray then rolled them on. Seemed to do the job (Y)
Edit: Your a full member- why not post in trials chat? :D
Edited by OnzaKid
Unless I havent read this thread properly. Have you tried putting them on without anything yet?
My grips took about 20 minutes of twisting and pushing them on and eventually they were on perfectly. They haven't slipped at all since. It hurts your hands alot putting them on though!
the way i did it was just soke the bars and the inside of grips with WD40 then push them on rotating them on. I did it and it was easy peasy...
Wd40, you idiot, bet your grips never stopped spinning!
I use hairspray, because I have it lying about the house, put a set on today, just do a light spray top and bottom of your bar, then a little just inside the lip your going to push in.... DONE
Changed my bars, today, new bars on with grips in sub 5 mins, tis simple.
as ali said ,clear laquer spray, is te best, i puted them once with laquer spray (on my dirt bike) but i didn had enough for other pair of grips ( on my trial bike), so i used coca cola, and it works great, put some coca cola on bar then put grips on and leave it for 5 min and when it is glued it wont rotate
