Big Click Every So Often On Onza T Pro Can U Help
Is it definitely a click or a quick creak?
If you're still using the original cranks, Which i'm guessing are square taper, the BB might be screwed. Mine used to do it all the time when I had them. Upgraded to Echo ISIS cranks and not a sound since
if you can't afford to upgrade, try stripping your crankset and looking for signs of wear, then stick it back together making sure to grease where necessary and properly torque up your crank bolts
where's the clicking comming from? how loud? does it do it when your doing something?
ite m8 it cums from the frount freewheel it happens like 2 or 3 times a week and i ride every day so could the frount freewheel need to cum of and give a good old clean and grease up i will try that
