Hope Mono Trial
coppo
Hi i just signed up to forum today so hello all.
I used to ride loads when was younger but just gettin back into it now.
anyway its time for a new front brake what do you think of the hope i ride a 26. i had a 4 pot saint on there but was a bit pants.
was guna order tonight from tarty do you recomend 200 or 180mm discs
cheers coppo
Well i had a hope, think it was a hope mini. They are pretty amazing, but they are so easy to break. They are a complete hassle to be honest. If i was you, i would order the Avid BB7 i think it is, they rock! Its all up to you though. And when hopes get contaminated, they are so hard to get clean, mine got binned it was so hard.
So cable disks for the win mate.
Oh, and welcome to Trials-Forum!
  • Like 1
? none of that is true, i have tried lots of front brakes (magure louise, hs33 with a grind and smooth and loads of pads, cable discs) and i must say i have a hope (old style with old lever) and the performance is so good, i thought the louise was good but my old batterd up hope with a bent rotor and nearly dead lever is just so good. outperforms any other brake for trials (Y)
None of its true? Haha thats weird cos it happened to me.
Oh, i thought you meant that they get contaminated easily and are hard to clean wasnt true.
Sorry.
doesnt any brake get contaminated easily? its so simple to happen, spillage of substances?
it happens the same, something funny go's on pads = contamination.
Edited by josh barker
Don't forget it'll need to bed in a little so don't be surprised if it's not awesome instantly. Bit of water and some pedalling/brake dragging should sort you out on that front though :)
yeh i was guna put it on my xc bike and go for ride found this to be good with previous brakes. just a tip for you all
Sorry.
They won't get contaminated any easier than any other disc, unless you f**k it and it pisses fluid all over the rotor/ pads.
And if it ever gets really badly contaminated, new pads and rotor and you've pretty much got a brand new brake again...
Get one, i've sworn by them. BB7's just feel too wooden, Hopes are beautiful.
i have tried a couple of hopes and they never really blew me away, but then again there are many more people that swear by them than dislike them.
the bb7 was fantastic, although sometimes feel wooden, they can be adjusted so many ways that you can get the desired lever feel
im probably a little biased though as i have never actually owned a mono trial
Had Hope mini, Old BB7, new BB7, Mono trial and gusset disc...along with some maggie setups.
Best for power was the magura ( cousts light sharp grind ) so much bite was lovely up to front.... next was the avid, (\although i have snapped 3 calipers all old style ) pretty close to the magura just with masses of spoke flex as to be expected on a stock. The mono trials was next best but not as much hold or bite as the BB7 for me :).
Brand new I'd go avid, second hand hope all the way..so much better value for your money.
I've used both BB7 and hope's and to be honest if you look after them there's not that much difference in them
But i do love my hopes a lot more, I don't have to mess about with it half as much as i did with my bb7.
Hope are also amazing with Warranty if anything did go wrong too.
Both BB7's and Hope have there pro's and cons though.
Edit: I used the new style BB7 and i'm using some fairly old mono trial calipers and the new tech leavers on my hopes.
Dale
Edited by Dale-Hill
