Atomz Quark 2 20"
Mark W
Jesus.. do they want to copy anymore of there products? Front and Rear rims, atomz 96 click anddd the stem..
Not too bad though..
EDIT: rear tube fail.
- Affordable 20" full bike from Atomz.
Frame and Forks
- Frame: Atomz Quark 2.
- Forks: Atomz Quark 2 Disc Only.
Wheels
- Front hub: Atomz Elitis Disc, 32h
- Rear hub: Atomz Elitis Disc, 32h
- Chain tensioner: Atomz Single Speed
- Front rim: Atomz Elitis 32h, drilled
- Rear rim: Atomz Elitis 32h, drilled
- Spokes: Atomz Elitis
- Rim tape: Atomz Elitis
- Inner tube (front): Atomz
- Inner tube (rear): Atomz
- Front tyre: Maxxis Creepy Crawler 2.0"
- Rear tyre: Maxxis Creepy Crawler 2.5"
Brakes
- Front brake: Hope Mono V2
- Rear brake: Hope Mono V2
Drivetrain
- Cranks: Atomz Elitis ISIS 160mm, Black
- Bashring: Atomz Elitis
- Freewheel: Atomz 96-Click
- Chain: Z610-HX
- Rear Sprocket: Atomz Splined Single speed 12T
- Pedals: Atomz Magnesium, Black
- Bottom bracket: Atomz First ISIS 127.5mm
Steering
- Headset: Atomz internal
- Stem: Atomz Forged 150mm x 30°
- Grips: Atomz foam
- Handlebars: Atomz Elitis riser
Geometry
- Wheelbase: 1005mm
- Chainstay length: 350mm
- Bottom bracket rise: +80mm
- Head angle: 71.5°
Weight (including pedals)
- 8.86kg / 19.53lbs -
Edited by Laurence--Trials
Interestingly, Atomz brought this design of rim out before Onza.
Rear tube fail?
I saw Rob Poyser running the prototype of that rear rim and we chatted about it at the last comp I ever did, which was in 2008. :lol:
AT LAST trials has followed the rest of the world and opted for post mount. Strange tyre choice though, I would have expected it to come with Try-Alls, I thought they were kinda like sister companies?
Shame you can't get a trials brake with post mount eh :P
No no no, Atomz and Koxx/Try-All are competitors!
They will be a soon as we have photos.
Because the tyre isn't fully inflated.
Oh right, am i aloud to ask price, weight and if you have the 20" too?
Cheers for telling me that, always wondered why they went in.
After looking at the bike a little more, i'm taking a bit more of a liking to it.
EDIT: is there a HS33 version?
not a trials brake, they're designed for XC really...
This is the same for vee brakes and Magura's, doesn't stop people using them for trials :S
BB7's (and BB5's) are the most powerful disc brakes that I've come across whilst riding trials, maybe I'm slightly biased towards them over a Hope because I much prefur the feel of cable brakes.
Just because a component doesn't say "trials" on the side of it, or is not deisigned by a trials company doesn't necessarily mean that its not trials worthy..
Did you just try calling up about this?
Either way - it's a special system that basically only works with the Atomz frames and the Atomz hubs. The hubs have a different sized axle in them to conventional hubs, and that axle runs through an un-threaded, closed dropout through the hub into a threaded, closed dropout on the other side.
Nah wasn't me, I'm far too skint to be interested in something like that!
Atomz hud and axle system best so far by a long way, no messing around no lining up love it Danny Butler and Ben Slinger both using this system now and very happy with it, = winner.
as for the post mount brakes again mint, no messing around with shims etc its the future by a long way.
Dave
