Diamondback Kabuki Bottom Bracket
krazykid009
Hey all,
I today went down and picked up my first ever trials specific frame, a Diamondback Kabuki Mono, to replace the old Giant Boulder I was using before. Upon getting home i noticed that is has a really weird bottom bracket size, coming in at a 100mm shell. Does anyone know where I can get a bottom bracket that fits this, preferably square taper or if not then its going to have to be ISIS. I need to get one ASAP otherwise I have no bike to ride : Please help me.
Thanks
James
Edited by krazykid009
Have you tried here?
Actually mate yes I did and the only ones I could find are through axles and the Howitzer which isn't compatible with any normal ISIS crank meaning I'd muck up my drive-chain as the crank-set that fits it uses a spider. I'm currently running a 18-16 but a crank-set with spider would mean i'd have to run 22-18, which would be completely different to what I run now.
James
There are some about. Quick scan on CRC kicks up this one but that's big bucks, there are more reasonably priced alternatives out there.
If all else fails, contact the place you bought it. They may well be able to get you a replacement.
Remember that if you need to change frames you'll have to change BB too...
The bracket you need is Truvativ Howitzer BB 100mm shell size x 66mm chainline select bikes £48.99 last time i asked anyway.
They only make an isis this size iv looked.
Edited by Earl
Can you use normal ISIS crank-sets with it or is it done so that you can only use the Truvativ crank-sets
Thanks
James
Thanks
James
I'll let you know later as im out the house at the moment and iv got the bottom bracket on its way to mine by post as got one yesterday on here ill post as soon as i know ok mate.
Otherwise i guess it would fit fine.
Edited by Earl
Wasn't tryin to be a cock with that lmgtfy jobby, just never used it for owt before!
The only one I found that'd work with normal ISIS cranks is that FSA one but it is very pricey!
Just out of interest did you buy the frame brand new or 2nd hand??
The frame was second hand and it was cheap, and it's only for a muck around bike to use for school and stuff, and to ride until I get my mod in November. It won't get bashed around too much so dosn't need high spec components. I have found a Truvativ Howitzer BB on ebay and have got the Cranks that go with it from the guy who sold me the frame so it is all sorted now.
Thanks guys for all your help.
James
