24" Echo Lite Chain Tensioners?
Carlperkins
the 24" echo lite frame comes with 2 integrated chain tensioner's. they're pretty much 2 long grub screws with a 2.5mm allen key spot on the end.
they always wobble loose and i have to tighten them up every day before i ride, but recently forgot and i've lost one now.
anyone know where i can get them? cant find 'em on tartybikes.
Shame to hear that you've had that problem! From the looks of someone's I saw a couple weeks back it seems like just a regular grubscrew you can get from any good fastener stockist just to backup the above suggestions!
When fitting the replacement(s) maybe blue loctite could help a bit to stop them from coming loose too quickly. I think the worst case scenario is if this issue kept arising and the dropout threads got worn out or stripped a bit.
Hope it gets sorted soon!
cool, you know what size it is adam? m4,m5?
i've looked but cant find one thats like an inch long.
The same as the one you've still got in your bike :P Think it's M5 from memory, but your best bet is to take the other one down so they can simply match it.
