Cleaning Out My Freewheel
D Rock 45
I was out riding to day and my echo sl locked up and wouldnt coast, i thought that was the end of its life having it for 2 years now but it freed it self up when i was pushing it home. I would take a look inside but with the lockring being on the bashring side i can take a look, also dont have a sturdy vice to hand to take it of.
Took my crank arm of and sounds ok but is very sloppy, slow to engage.
So is it time for a new freewheel or can i salvage it with new inside pawls, springs, bearings
So ive found and bought two second hand sl's lots of spears :) one just needs a clean out and pawl replace which i have, so i am just blasting the thing with gt 85 drying it all with a soft cloth then re-assembling with a small amount of grease on the bearings but i was told not to as it would make it skip. is the true or is it ok
Edited by D Rock 45
You can´t buy them seperately,so you will have to buy a new one I´m affraid.But you can always try to spray some gt 85 in it and see if it gets any better...
You will have to take it apart to be sure but it is probably a damaged pawl. Don't use it until fixed, will cause more damage ;)
am thinking its thats but nothink is rattling around, i wont be using it for i wile then.
I will spay some gt in when i have it open
looking on tartys you can buy all the parts
Edited by D Rock 45
How can you fix it if you can´t buy pawls separately?I´m interested in this too as my SL isn´t entirely ok I think.
You would have to either buy a new freewheel and use the broken one for spares or source another broken freewheel and hope the parts you need out of it are in working order.
You can't buy the parts for the echo freewheels im afraid.
looks like a new freewheel then, if i cant get any parts for it
File? I used to fairly regularly reprofile the pawls in my ENO to remove the burrs. Worth opening it up to see how bad it is- you need to take it off to replace anyway.
Edit: Ok, that's f**ked.
looking closer at mt freewheel the casing has cracked not sure how long its been like that.
buying a second had one, getting the best bits of both hopfully to make a good one
If Im correct in assuming you've done what my my mate connor has done to 2 different SL's,
simply put it pocket side down in the vice, gripping the outer so the teeth are touching the top of the vice jaws, mince the vice 'til you feel harsh on it, and you should be able to 'backpedal' your body away from the lockring, which in turn can be gripped, and backpedalled away.
THIS IS IMPORTANT: check that your crank threads have not been damaged like connor's were, his stripped the very next ride, and he was only backwheeling a 3 set of stairs (badly, with rough technique). Now imagine that on a drop gap...
I'm not saying your cranks will definatly strip or be damaged, just check.
EDIT: If I am incorrect, then forget I said owt.
Edited by CC12345678910
i got it of today, two pawls were snapped in half and the small crack in the first set of pictures was nothing, it ran right the way round inner case, got a second hand one ariving tomorrow hopfully. Going to take it apart clean it out and re-assemble it :)
All sorted
That's not nothing!!! thats what strips your cranks because the thread expands from 1.37in internal Diameter to 1.375in when it cracks through, overtightens as you kick and takes the crank threads with it.
I'm sure it used to say stuff like that the freewheel pages on tarty's.
Even if my reasoning is wrong, I really wouldn't bother taking the risk.
HERE WE GO
http://www.rocknrollbikes.com/trials/cranks/tensile-comp-cnc-7075-trials-cranks.html#Size=170mm
bottom of the page.
Or from tarty's
Additional information http://www.tartybikes.co.uk/cranks_pair/trialtech_sport_forged/c514p10467.html
HERE WE GO
bottom of the page.
Or from tarty's
1,375 is used in WI freewheel ;) But of course it´s not good to run cracked parts especially drivetrain parts.
i never noticed it untill i took it of and then it was even worse when i took it of the crank arm my threads are ok but now it exsplanes why i had a tight spot, i deffinitly wont be using it again. its in the bin. only parts i have left are 7 pawls 7 spings and all the bearings also the shims
