Cranks
trialsiain
It won't change your gear ratio, just change the number of revs. 165mm would be best really
Basically you will be traveling at the same speed but your legs will be going much slower which helps for run ups.
More clearance
You will lose around 3% leverage which you won't notice
More clearance
It might just be 'cos I'm fussy as shit about setups, but I found it was a noticeable difference just going from 170s to 175s. Dropping 10mm would make a reasonable difference in feel?
I sort of hate the feel of short cranks in terms of the rotation of them and the way they make my gear ratio feel, but it's horses for courses I guess. I prefer that lighter geared feeling from having longer cranks (but still having the power as the ratio's the same), but again, it's personal preference to a large extent.
Basically, if your cranks feel fine at the moment then there's no real point in changing them.
More clearance
I don´t know if you´re kidding or actually being serious.
Lol you bore me,
Back on topic like mark says its personal. Best bet would be to try some out and see if you like or not.
I bore you but you keep me excited with all this unlogical stuff you say all the time.It is personal preference to an extent, but physics works for everyone the same,longer crank=more leverage=more power.Your problem with run ups is weird too,what if the run up is actually a steep hill?you will have hard time(harder) to even get to the obstacle with 165mm.And clearance isn´t an issue with modern geometry frames either.Oh,most elite riders use 175mm cranks,I think they know thing or two about clearance and run ups.But you can use whatever you like,but it doesn´t make it right or logical ;)
Urm no they don't sorry but your just talking utter rubish now
Even kenny has changed to 170mm about a year ago.
I think koxx even supply full build 26" bikes with 170mm cranks ?
Logically- the shorter the distance the muscle has to travel faster and more explosive it can be
Edited by dave33
Logically- the shorter the distance the muscle has to travel faster and more explosive it has to be
Not an advantage by any means.And http://www.tartybike.../c47p11509.html 175mm cranks ,not that it matters because pro riders can choose their part how they want obviously.
Edited by ghostrider88
