James Hyland's RockMan Slate XL
Mark W
James came by the warehouse yesterday to build up a new bike, and here it is:
His bike is built around the RockMan Slate XL frame with a set of RockMan Spade forks.
His rear wheel is the K2 Rim laced up to a TR Hub. The rest of the drivetrain is set up using a Trialtech Sport Lite BB with Try-All ISIS cranks, with the latest Symetrik bashring and an Echo SL 108 freewheel. That's finished off with a pair of RockMan Single Cage pedals and a KMC Z610 HX chain.
His front wheel uses the new Trialtech Sport Lite rim laced up to an Echo SL Front Non Disc hub. 3x lacing to keep things nice and stiff (at James' request!).
Both of his brakes are 2011 HS11 brakes, using water/antifreeze bleeds and Try-All Croco Yellow pads. The stem is a Try-All 3D Forged 150mm stem with the Try-All Carbon bars, cut down a touch to around 700mm.
James rode (well, destroyed...) our indoor setup after he got it built up, and we filmed a couple of clips. He's editing that video over the Xmas break so that should be out soon hopefully!
  • Like 1
looks soo nice i was wanting one but it want in stock when i needed a frame :(
and the bar angle actually works i dont see why people keep going onabout it, i tryed it and it sort of worked for me but i just but my bars back to normalish postion because i look shit with "carthy bar angle"
