inspireds with ffw pros and cons need help
miketrials1995
Cons
Crappy gear ratio
more rolling resistance maybe ?
That make no sense at all...
As for rolling resistance, I doubt there is any more resistance than an Echo SL 108 for instance - but it is not noticeable either way.
Edit: I see you're only talking about FFW? If you are riding a street 24" or 26" a la Inspired then Pro II's are great.
Edited by AndrewEH1
  • Like 1
You can run the popular ratio's on both, I run 18-14 with a chris king, but I like it a bit light, 18-13 is pretty close to factory fourplay.
I find the main difference is that my rear hub is much more sealed to dirt, sand and water than when I was FFW.
FFW is probably lighter.
Your number of engagement points on a RFW will depend on your ratio but will most likely be much less than on an echo SL.
The splined sprocket on a RFW makes it easier to experiment with ratios.
RFW will allow you to run more crank options, like bmx style or hollowtech.
Trousers getting caught isn't to do with FFW, its to do with the size of the front ring. Mine get caught in my 18t sprocket.
But overall, I would be happy to ride either.
