Air King problem
jack dickinson
How do pedals "f**k up"?
the axel doesnt spin, it cant get it to turn. so much so that when its tightened into the crank it unsrews rather than spins. tarty say they will have a look so im willing to sent it back.
also just pumped up to 80 psi rode around for a bit and ddidnt work let tyre down and is the same.
What rim do you have Jack?
Sounds like you have the same problem as I did and I found that I had a really small dent in my rim causing it to not let the tyre seat properly at low pressure.
I have tried the tyre on another rim that isn't dented and it is fine. I am talking about a really really small dent too (In a trialtech sl rim).
I wish Conti used Wire bead :/
same rim, tt sl, but i bought the brand new and was like that since new. and was the same on my old rim which im certain wasnt dented
