hs33 weirdness / reusing barbs
jeff costello
i've ripped out the brake cable of my 2014 hs33 a few times now, so i had to fix the hosing. my brake came with 3 barbed fittings on the slaves (shroud nut and olive on the lever) - 2x m8, 1x m6.
without giving it much thought, i've just hammered the old barbs into the new hose. is there anything wrong with that? maybe even dangerous?
also, i wanted to order some spares because i don't want to be left with a non-working brake. i can't find m8 barbed fittings anywhere. am i supposed to use shrouds and olives instead?
thanks
Re-using the barbed fittings is fine (Y)
If you're breaking hoses a lot then a shroud nut and olive would probably be better for you as they're easier to fit. Might be worth wrapping your hoses with some electrical/insulating tape near where they join the fittings to try and maybe reinforce them a bit? It might help out a little bit, at least...
  • Like 1
A splitter would be a good shout if you've got the option to route it like that (Y)
The M8 barbed fittings probably aren't readily available because most Magura importers/distros are absolutely shocking.
EDIT: If you're getting a splitter and you break hoses often, going Trialtech would probably be best as fitting/removing hoses is way easier because you can just take the barbed fitting out of the splitter and work on the hose individually without having to hack it off the end of the integrated fitting you get on some splitters.
this means that the m8 port of the slave can take both, the barb and the shroud&olive?
yes! was planning to do just that.
Edited by jeff costello
i've mentioned in the "worst screwups" thread that i've killed my lever bleed screw. the plastic one. the head totally crumbled to pieces, but the bottom is still stuck in there. is there anything i can do to repair that? or do i have to throw out the lever? ( i already ordered a replacement lever which should arrive tomorrow, so i can keep riding. but i'd still like to fix the old one to keep as a spare) one guy on here mentioned the re-cut the threads with a tap. is that the only way? i have zero experience using a tap. i wouldn't even know what kind of tool i should get. should i send it back to the bike shop i bought the brakes from?
Result. Cheapskate twats making stuff out of plastic, they've ruined their brakes doing that
Must admit i've been put off buying new magura stuff. Especially the Carbotecture levers. I dont care how strong their tests say it is. A short Google search brought up numerous stripped threads, oil leaks, and one sheered lever.
Thing is, that's also true for any brake ever used on a trials bike.
Still think i prefer alu, takes regular threads, repairable to a degree.. Helicoils, over sized threads. But the breakages and issues i've seen have been more XC whippet types. Has anyone else seen that youtube video with a MT8 seaping oil out of the weight saving holes at the back of the lever. Literally looks like someone squeezing a sponge.
I know a lad from away that had this happen to a racing line master/full brake - the split clamp one not the (trials addict list it as the LS7?)
05 maggie improvement I have. Where it was machined in between the bar clamp bolts like hope do, the tool must have gone too deep by a fraction, made the wall thickness weak and it seeped out over period but increasing got worse . Its a pain I know, and I have been on the wrong end of it often enough, but that is what warranties are designed for; that one in a thousand where no visual QC inspection could have spotted it.
Having said that, in the world of bikes, some of the stuff that arrives though my door I feel is appalling at times. If a brand burns me like that soon become very stubborn about their products, and I'll be the first to admit it too.
I too, am becoming like this about magura's later/latest offerings.
Edited by CC12345678910
