Titanium bolts
LEON
After seeing someone with Ti caliper & adaptor bolts at Tarty Days I've gone all rainbow titanium, All I need now is some rainbow Pro 2 axle bolts, I've checked Stan on Tarty but they only come in silver, Ebay gave no joy either, any ideas? Maybe some car brands do flashy bits?
Check Tarty again I think you will be presently surprised Edited by jack1987
  • Like 1
While I'm here, how suitable are ti bolts for things like axles, stems, brake caliper & adaptors? I know it's not as strong as steel but by a big enough margin to worry?
You do realise that 6al4v titanium has a UTS of 950 MPa? A high tensile steel bolt (grade 8.8) has a UTS of 880 MPa, not sure what grade most of the cheese bolts used in the bicycle industry but I don't think they're much above gr8.8 :)
edit: make sure you have plenty of copperslip on there though!
Edited by forteh
  • Like 1
Well that's reassuring! No I didn't realise any of that lol, several people have told me they've had really bad experiences with Ti bolts, these are grade 5 (I think) Ti alloy bolts, I have the Stan M10 rear axle ones and several m6 bolts mainly on stem, brake adaptors/calipers, these are the ones I'm most worried about.
So caliper & adaptor bolts are good to go? I'd hate to break some major parts for the sake of being a tart.
I've used (and still use) a bunch of different Ti bolts on my bike, and I generally just use whatever grease I have lying around. Think it's some lithium grease that's currently stopping my rear axle bolts and axle becoming one, and it was the same stuff I used for my dinky stem bolts before too.
Grade 5 titanium is 6al4v so you're good for strength :)
Generally a proper anti seize paste will be better than plain grease as it will have a heavy particle load that acts as a sliding barrier between the materials to prevent galling. When the carrier grease finally dries/washes out the particles remain and will allow you to undo the fixing.
