Uber Wheel!
Frenchman
Something i thought i should share.
Pete Wright's new rear wheel.
This is taking wide rims to the next level!!
Surly large marge rim drilled by bigman.
Profile 6 speed hub (32h)
Maxxis 2.7" highroller.
He brought it round mine earlier and it isnt offensively heavy.
Good job he is building a custom frame as there isnt much chance in fitting one of these in a conventional trials frame withoug running disk.
cheers
frenchman
getting a cross-over long enough to clear the tyre?
Why would that be difficult? just get more hosing?!
Also, surely if he's getting a custom frame he'll get a custom booster to match.
why are there bumps coming through the drilled holes on only one side of the rim?!
man a rim that wide is pointless, nowt wrong with a good D521
Edited by JonPace
hey
As i said in my post he is building a custom frame around the wheel so the brakes will be fine to set up. crossovers are not a problem as you can make them longer.
I am not quite sure of the point but i can say one thing for sure it is different.lol
cheers
I'm guessing he's not using rim-tape or something? Tubes always seem to bulge a bit round the valve?
Looks like its gonna be a lot of hassle but i must say it looks the nuts...
i didnt relise until the second pic actually how wide it is....double drilled rims is a bit extreme!!! It seems alot of people get carried away when they get to drill their own rims.
Ali Clarkson had a triple drilled rim when i saw him at hook woods....i was looked like a megamo rim he had drilled himself!! :- :angry: it looked sick!!
Seeing as the tyre's only 0.02 of an inch wider than the rim, isn't it going to be Pop-off-the-rim Central as soon as you do anything remotely at an angle?  :angry:
i dont think so, i have only had problems popping the bead on tyres when using a narrow rim on a wide tyre. I guess only time and petes riding ability will tell.
Hands up who thinks he'll get bored and move onto another "whacky" idea before he finishes this one? We still haven't seen his coffin PC case with watercooling and 12 fans, his bike shop, or indeed his helium-filled pashley. Ho hum :angry:
That looks kool and if it functions as well as it looks it should be a bomb. There are so many disadvantages but if he can overcome them all (highly unlikely) Then Well done to him. If the rim is to large in the first place what was the rim designed for? Downhill? But I didnt think Surley parts were made for Down Hill?
As you can tell im still learning :angry:
Tom
