Basic Electronics Problem
cant_ride
I can do pretty much everything in electronics apart from finding basic circuit parameters... dont have a clue why that is... and on that note i still have no clue how to find .... Ix and Vx in the following circuit ... help me out with some kind of walkthrough if you've got time. :)
oli ( the dunce )
i did things like that in the electric products lesson at gcse level and i cant remember for the life of me how to do it :">
i'll try and dig out some notes if i have time tonight :)
ta
Will
Edited by WILL ARNOLD
I cant work it out, im so going to pass my exams :)
Im thinking I has to be 2A just like the other one too which would then make V = 48 because the total R = 24
But theres a part of me thinks I is differnt to the other one
I really should know this :)
erm ... i think i might know ohm's and kirchoffs laws... plus thevenin, norton, superposition etc...
like i said this is at a high level ... the hard part comes after ive worked this lot out.... but i can do the hard part if only i had Vx and Ix ... and u only need ohms and kirchoffs to work it out i know that much.
oli
glad it is :)"
But doesnt kirchoffs law just state that if you have a 10v supply or something and have say one resistor the voltage drop across that resistor must be 10 v????
I dont see how that can help us if we dont have the Voltage to begging with
glad it is  :)"
kirchoffs voltage law yeh ... but kirchoffs current law is what i need to use. :) ... well both of them actually
I have the answers on a sheet I just cant seem to get to them
oli
Haha, sorry Oil.
http://www.google.com
I know jack shit about electronics :) *
*may not be true.
hahaha ... google teaches me the same as my books and my lecturer... which is the theory... not where im supposed to start ?? :)
by the way my name's oli .. not oil .. hohoho :unsure:
oli
by the way my name's oli .. not oil .. hohoho  :)
Oops :"> Sorry, hehe.
I haven't really looked at it properly... but surely theres some way of splitting the circuit down into smaller bits, and then applying the theory to it? Just an idea...
'fraid not tank rider ... and i need V and I ... not V and R
come on theres gotta be a genius somewhere !!!!
oli
erm yeh splitting it is what i was trying to do but it still wont work out for me  :)
oli
what sort of answers do you think it should be?
well ive done it :unsure:
get on your knees behatch :unsure:
right first thing you need to find the current in the upper part of the circuit over the two parallel resistors (3 and 6).
V through both resistors is the same.
The voltage through the 3 ohm resistor is 6V, divide that by the 6 ohm resistor to get 1 amp flowing through it. Add those currents together to get 3A which is the current flowing through the top part.
The total resistance from the top part is 9 ohms. The voltage this gives is 9x3=27V, just as you said it does :)
Now onto the current in the lower part.
The total resistance is 15 ohms.
The total current passing through the lower part is 27/15=1.8
the 11 ohm resistor takes 11x1.8=19.8V from the 27.
27-19.8=7.2V left for the resistors in parallel.
finally 7.2/12=0.6A :)
you best be greatful (Y)
