Your Rear Brake Setup
Michael Hardman
Lever: silver Magura with black lever blade. Bodged tpa
Callipers:silver magura 04
Hose: Braded Magura, water bled
Mounts: 4-bolt
Pads: Plaz
Rim: Old echo 19'' , lightly grinded, tar
Booster: Echo 04
My brake works shit without crap loads of tar.
A grind holds less thatn a week.
Any suggestions.
Lever: Standard HS33 04
Calipers: Standard Magura
Hose: Magura Black
Bleed: Water
Brake Mounts: 4-Bolt
Pads: Brown Koxx Bloxx
Rim: Onza Ronnie with tar (Can't be arsed to grind)
Booster: Onza Carbon 4-Bolt
rb lever
magura hs33 slaves
magura black hose
4 bolt mounts
standard magura boster
brown koxx bloxx
mavic D521 rim with grind
brake works ok considering the pads only just touch the rim and the rims to narrow(tpa screwed all the way in) (Y)
Lever: Magura '05
Hose: Magura black
Bleed with: Water
Brake mounts: 4 bolt
Pads: Plazmatic Fjas on custom aluminium backings
Rim: Alex DX32 with fresh grinds every 14 days-ish.
Booster: none
Lever: Standard HS33 04 Black
Calipers: Standard Magura Black
Hose: Magura Black
Bleed: Magura Oil
Pads: Heatsink Konigs
Rim: Onza Hog - Absolutely smooth (Y)
Soon to be grinded! Tonight i think (Y)
Can't wait..
Edit: Update;
Now grinded and it's the sex. No joke. I love it :D Hope wear rate isn't very fast :-
I haven't noticed anything yet though. Well loverly :D
Edited by mod661
avid ultimate lever
linear slick cable (soon to be a nokon)
sd7 callipers (soon to be avid ultimate) (Y)
spanish fly pads (soon to be new heatsinks)
atomlab aircorp rim-light grind (soon to be a d521 with a light grind)
speacial bendy noodle-moves with the brake giving a better cable angle B)
no booster as yet-no need-may run a carbon xtr :)
uber nice brake as it is, gonna feckin rock with the upgrades-when i get my curtis (Y)
used to run a standard 2 bolt, oil bled, magura, with cnc blade and koxx pads on the same rim and that was pretty good too :S o yeah it has a home made booster cos of the seatube hitting the oe maggy booster
This lloks like fun, Ill join in B)
Lever: Fresh Products Prototype
Callipers: Magura
Hose: Black Magura, water bled
Mounts: 4-bolt
Pads: Rim Jam Blue
Rim: Onza Ronnie, lightly grinded, tar
Booster: Echo Control
Lever: Standard Magura 04
Calipers: B)
Hose: Magura black
Bleed with: Mineral oil
Pads: Zoo!
Rim: Try-all, smooth rim.
Booster: Onza carbon.
:S
Calipers:  B)
Hose: Magura black
Pads: Zoo!
:S
how are you liking the Zoo! pads?
Wish I could get some in the U.S. :)
Wish I could get some in the U.S. B)
On a grind they're good but they wear down in a few rides. On a smooth rim apparently they're ace!
If you want some have a word with Adam or Dave at TartyBikes i'm sure they can send you a pair over! :S
Edited by Siders77
Lever: Standard Magura with CNC lever
Calipers: Magura
Hose: Unex bridge hose with Goodridge main hose and stainless steel connectors
Bleed: Magura Royal
Pads: Heatsink (Batch B white)
Rim: Onza Ronnie with a harsh grind
Lever: RB lever stripped from red to bare metal (and carbon fibre obviously)
Calipers: Magura - white
Hose: Standard black Magura hosing
Bleed: Whatever the bike shop put in, but I usually use citroen brake and clutch mineral fluid.
Pads: Coust
Rim: Onza Ronnie, clean with no grind
Booster: Brisa carbon fibre 4 bolt.
