Skeedy Posted September 13, 2005 Report Share Posted September 13, 2005 (edited) Hey, I was wondering about the quality of the viz rear rims and the rear hub. If anyone here has tried them or owns them, if they could comment that would be great. Also, the cost, I was wondering about how much they cost, but since I don't know pounds or anything, could you also put the cost of an Alexrim DX32 and XT hub so i can compare? Thanks, Steve the Canadian Edited September 13, 2005 by Skeedy Quote Link to comment Share on other sites More sharing options...
Mark W Posted September 14, 2005 Report Share Posted September 14, 2005 Auto Reply The topic starter has been validated. Moving topic from New Members Chat to Trials Chat. Quote Link to comment Share on other sites More sharing options...
Skeedy Posted September 14, 2005 Author Report Share Posted September 14, 2005 Yes, I am finally a member, thanks you very much! And I am sure that there will be a little more response here than in the new members chat. Thanks again, Steve the canadian Quote Link to comment Share on other sites More sharing options...
Synergy Posted September 14, 2005 Report Share Posted September 14, 2005 hey hope i can help im in college at the moment. i bought a viz hub and mod rim. dont use it much as its too big and my frame broken lol, but the hub is amazing quality id say and not had problems when i used it there about £40 rim £40 hub Quote Link to comment Share on other sites More sharing options...
sjpearless Posted September 14, 2005 Report Share Posted September 14, 2005 i run viz rims and hubs. i know your gonna say im biased but there mint. seriously. koxx rims with eyelets = plus smoothest bearings = double plus simon Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted September 14, 2005 Report Share Posted September 14, 2005 aluminium axles= minus.... make sure you get the steel axle :angry:" adam Quote Link to comment Share on other sites More sharing options...
SQuiT-man Posted September 14, 2005 Report Share Posted September 14, 2005 Overall I would have said they were fine, however I was a bit disapointed with my viz rim that I purchased. Its 40mm wide in some areas and 39mm in others (it isnt even on the seam where the rim joins together), which is pretty bad considering I run a rim brake and chose to not have a disk hub to save a few grammes- it means I cant modulate my front brake much at all, or set it up too close to the rim as it may rub on certain areas and not in others. If Id know this I would have just got a disk setup atleast, its probably what ill end up doing in the end. Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted September 14, 2005 Report Share Posted September 14, 2005 Overall I would have said they were fine, however I was a bit disapointed with my viz rim that I purchased. Its 40mm wide in some areas and 39mm in others (it isnt even on the seam where the rim joins together), which is pretty bad considering I run a rim brake and chose to not have a disk hub to save a few grammes- it means I cant modulate my front brake much at all, or set it up too close to the rim as it may rub on certain areas and not in others. If Id know this I would have just got a disk setup atleast, its probably what ill end up doing in the end. ← Your rim might be a factory de-fault? you wont know intill you have checked every single V!Z rim out there to see if they are all the same? Anyways, i think that if they perform as good as they look, they will be sweet as feck!!! But IMO the headsets looks gash, they all multi coloured!! but, like everything else with me, i will probably grow to like them :angry: Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted September 14, 2005 Report Share Posted September 14, 2005 Anyways, i think that if they perform as good as they look, they will be sweet as feck!!! ← Just cos you like Green (Y) All the Viz rims I've built so far have been the same as yours Scott - it may be worth you taking an adjustable spanner to the offending area and bending it true? (Like you would with a dent). Just an idea! :angry: Quote Link to comment Share on other sites More sharing options...
Dan@Trials-uk Posted September 14, 2005 Report Share Posted September 14, 2005 Your rim might be a factory de-fault? you wont know intill you have checked every single V!Z rim out there to see if they are all the same? Anyways, i think that if they perform as good as they look, they will be sweet as feck!!! But IMO the headsets looks gash, they all multi coloured!! but, like everything else with me, i will probably grow to like them ;) ← The headset's dosnt come multicolored. They come in a single colour :angry: (Y) Quote Link to comment Share on other sites More sharing options...
Phatmike Posted September 14, 2005 Report Share Posted September 14, 2005 So what the f*ck is on the left in the middle dan?! :angry: Quote Link to comment Share on other sites More sharing options...
Luke Drewery Posted September 14, 2005 Report Share Posted September 14, 2005 So what the f*ck is on the left in the middle dan?! :angry: ← Thats just what i was thinking. I have always had bad impressions of viz from general reviews on here. (Y)" Quote Link to comment Share on other sites More sharing options...
Dan@Trials-uk Posted September 14, 2005 Report Share Posted September 14, 2005 So what the f*ck is on the left in the middle dan?! :angry: ← Yes. There is one headset thats multicolored, But they just come in one color when you purchase them. Quote Link to comment Share on other sites More sharing options...
dave85 Posted September 14, 2005 Report Share Posted September 14, 2005 hmm, having "colourful world of viz" on your headset sounds like your advertising a very gay theme park... Quote Link to comment Share on other sites More sharing options...
STEVE-0 Posted September 14, 2005 Report Share Posted September 14, 2005 aluminium axles= minus.... make sure you get the steel axle :angry:" adam ← Ah! You beat me to it. Yea i bought a fixed rear hub and the alxe (silver) was apparently alu. I bent it in about 2 weeks and sent it back to danko for him to replace it with a steel one (black). Bearings feel good though, good quality. Steve p.s. I hate their new slogan 'the colourful world of viz' the headsets look utter wank! Quote Link to comment Share on other sites More sharing options...
James Quigley Posted September 14, 2005 Report Share Posted September 14, 2005 I'm not a fan of viz personnaly. From what I've seen and heard a lot of people dont, some do though. I'm not sure about the hex-holes on the rims, surely the corners on the hexs' just create weak points. Seem's to me that they're too caught up in making things that look good e.g. colourful. And if anyone was in pompy on Sunday and was nice and early in the square (guildhall) they may have noticed a little blue and black bmx type thing riding around, and to quote Spacemonkey ''It looks like that bike has bee thrown up on by Viz''. I thought that this quote pretty much sumed it up. However, my opinion probably wont count as I'm sure there are a lot of people out there who dont have a problem with Viz. Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted September 14, 2005 Report Share Posted September 14, 2005 Just cos you like Green :P ← Haha, iv just fell in lurve with that green headset now (Y) But my bloody gay bike only takes internals!!! :D lol Oh well :P Green V!Z rims once my money flows.... like 1 year away :( lol Quote Link to comment Share on other sites More sharing options...
mark-399 Posted September 14, 2005 Report Share Posted September 14, 2005 i had a old viz rim died very easily dented it an it cracked at the wear indercator all the way round the rim. big weak spot on the rim :D i dnt know what the new ones are like Quote Link to comment Share on other sites More sharing options...
Siders77 Posted September 14, 2005 Report Share Posted September 14, 2005 The only V!Z things I have used are the Grips and Pads. I wasn't impressed at all! The grips weren't bad but the pads came out of the backings and just didn't want to work properly! (Y) Another thing that has made me not buy V!Z parts is the SHIT customer service. I ordered some pads from Dan around 3 weeks before Christmas and a month or so after I still hadn't had them. When I bought some cranks from Dan (Second Hand) they were shagged. I asked Dan for my money back and he said that he couldn't give it back because what I bought was second hand! :D So over all I would just stay away from V!Z altogether Oh, and the new slogan= :P :( :P :lol: Quote Link to comment Share on other sites More sharing options...
Guest Posted September 14, 2005 Report Share Posted September 14, 2005 I suppose if you wanted your bike to look like something out of a kids t.v show you could run lots of different coloured parts, but there's no doubt you'll soon regret it and probably commit suicide due to the torturous verbal abuse all your mates give you for having such a queer bike with parts that have the same title as a dodgy magazine. Quote Link to comment Share on other sites More sharing options...
Skeedy Posted September 14, 2005 Author Report Share Posted September 14, 2005 alright, I thought about it and realized that since i ride street and do alot of sketchy spinning, a drilled rim wouldnt be the best bet for me..... Ive bent up my dx32 prety badly. So I'm thinking that I'll just get a surly single speed hub with another dx32 and a much lighter tire than I am running now. Thanks for the imput though! Quote Link to comment Share on other sites More sharing options...
