D521 In 04 Model Pitbull
Trials Dave
i am going to buy an 04 pitbull frame. i currently have a d521 rim. as the chainstays are wider on the pitbull compared to a saracen mad i was wondering whether i will be able to set my brake up so that it actually reaches the rim (or so i dont have to pull the lever to the bar) because as we all know a d521 is quite a narrow rim? cheers guys
Yeah a D521 will run on a pitbull, with a pad bodge, its quite fidley but cheaper than a new rim. i ran a bodge on my t-rex for about 6months. my brake worked fine (Y). i used four screws to hold old pad backings onto full brake pads. make sure the screws are countersunk though else ur pads dont fully recline. and keep checking them as they have a tendency to come loose - unless you use glue aswell!
Sorry to steal the topic a little,what echo rim is it which instead of the squares cut out,there is what looks like a bubble of glass near the spoke nipples,or am i just talking out of my arse? i believe craig lee scott has one on rear wheel..Please help...Thanking you :)
Linky
This one mate.
I ran a 521 in a 04 Pitbull and it worked fine without any pad bodges, and it was with worn Koxx bloxx, the only thing was the lever did pull in pretty much to the handlebar, but it didn´t effect the performance of the brake, and a mavic rim is much better then any of the wider ´cheese´rims out there for grinds as the material is better.
Cheers, Dan.
Edited by Danno
I have a ZOO Pitbull 04 and I run a D521 cd ceramic, you wont have a problem unless your HS33 Pads are Extremly worn down - check the pics
http://www.pinkbike.com/modules/photo/?op=viewℑ=571096
i would also like to add that zoo pads on ceramic rims are the Ultimate Brakes - Trust ;)
hope that helps
nice one. you've just filled me with confidence. im definitely getting the pitbull now. no bodge job sounds good. looks like you've got a nice ride there aswell. :)
hope that helps
hey. thanks. you've just filled me with confidence. im definitely goin to get the frame now. i'll prefer it not having to do a bodge job or gettin a cheese rim. cheers. by the way looks like youve got a nice ride there.
thanks man! yea its a great ride im way chuffed with it, try it with the zoo riser bars and Zoo stem you wont be disapointed (the geometry dosnt realy suit flat bars i used to have planet x pro trials bars but they sucked)
those pics are about a month old now - i just put on a hope mono hub and a KMC Kool chain. ill get some new ones up there soon!
i highly recomend D521's and as i said before the only time you will have a prob with the rim width is if you have almost no brake pad left - the pads on my bike had been on for about a month in that pic and Zoo pads wear down realy fast.
glad i could help (Y)
