Brake Oil
outerhope
hi just as a tip for enyone like me I got no cash.
i popped my rear crossover line this week and have just fixed it with a spare i luckily had kicking about,but i've got no oil or money, so after two days of not being able to ride i thought f**k it and filled up with olive oil out of the kitchen in the hope it would be a get me home job.
my brake has never been so good!!!!!!!!!!!!it locks on like glue and i've got some progressive feel. rock on olives!!
only thing is it seems to absorb air a bit so will need bleadig allot but f**k it it's free
only thing is it seems to absorb air a bit so will need bleadig allotbut f**k it it's free
Actually it's about 24p a litre! :-:P:closedeyes:
apparently baby oil is amazing. but i'm happy with water and anti-freeze, it gives a harder feel (Y)(Y)
also it's cheaper than cookin oil, since you can get cheap anti-freeze for about 99p and you only use a capful with each bleed (thats both breakes so half a capful per break)
Mike!!!!!
I am afraid you are wrong there mate the best stuff proven so far has been Citroen Hydraulic LHM oil. It is superb as I have it in my maggie at the moment. If you pop along to your nearest garage if they have it I think it is only about £5 for a litre which is a great price.
Hope this helps (Y)
Proven by who and what laboratory. I think You'll find that the vast majority of riders use nothing but water and maybe anti-freeze. Much snappier feel + response....
I've also read on here a guy who had his brake bled (lovingly, by his mates) with urine :P
the ultimate liquid i imagine would be petrol or parafin... thin as wd40 (wd40's made from parafin i belive) doesnt freeze like water and evaporates off rims if you spill any
downs are bleeeding it would cost about £5 and after 10min bleading it you be high as a god damm kite plus no one knows what it would do to the seals (petrols acidic i belive)
either water or maggura oil i belive are the only two options now realy but if any one reading this wants to blead their brake with water get DE IONISED WATER its what you put in car batterys and is ph neutral :lol: so now poping seals thanks to chlorine and florhine levels in tap water destroying them :P
I have spoken to a few people who have said the same thing including XC riders etc. :$ Sorry I haven't tried water so I may find it is snappier as you say but I would also like to point out that over time water will gradually wreck the inners of your Magura unlike oil which won't.
petrol might work till you spill some and some idiot drops a cigarette on it but oh well.
I'm using hydrolic compresser oil, its ace, its thicker than water but it works fast and no sponge at all (Y)
Edited by monkey gav
LHM brake fluid as mentioned above is pretty much the same as magura blood, just a mineral oil, of similar thickness.
I Personally use 2.5wt finishline shock oil, it is thinnner than magura blood (i believe magura blood is roughly 5wt) and HAS been proved to be better. magura service centre int eh US used to use 5wt finish line to blled brakes, as it was the closest they could get to magura blood for a while (for some strange reason), and they said it improved feel as it has more of a lubrcative effect. By usingthe thinner 2.5wt, you get a snapppuier lever feel that is also very consistent and smooth, with no worries about damaging the system or it freezing. I find it very nice to use.
Personaly im not keen on water, i dont like the hard feel.
I tend to use lhm citreon brake fluid from halfords, Its only about 5 pounds.
However if you do insist on using water make sure you put anti freeze in and use de-ironised water,
This way it wont freeze or rot the seals for a very long time :)
cheers
hmm i just use water, works ok for me. just my advice is be careful with certain hydralic fluid as im sure most types strip paint, magura blood doesnt obviously, neither does water lol :D
forgive me if i sound dumb i didnt pay much attention in science at school :lol: whats deionised water? and where can i get some and how much. forgive me if someones already said what where and how much i only scaned the topic :-
Clawz
Edited by Clawz114
