Ok 2 Questions
Ash-Kennard
The pads last freaking ages, had mine in a good two months now on a rough grind, in mud, wet, snow, rain, dry, sand, everything and i had mine cut back to around 4mm and they are only just wearing out now......
Excellent pads and the CNC backings will provide really good power through the brake.
Thats my answer
A ronnie will deffiantly fit Ash......
Also, the CNC backings on the heatsink pads is thicker than on a standard pad, meaning that it will be closer to the rim than a normal pad, so in theory it should give you no problems with setting up once worn....
I have a set of CNC red pads and have been running them on an 06 echo rim with a grind which was first put on just after christmas and they are still awsome, and they have not even worn 1mm yet, which IMO is pretty darn good.....
I have not actualy tried them on a fresh grind yet as the grind i have got them on now was 2-3 weeks old before i put on the pads.
So it is a deffiante yes to both your questions.
Adam
