Tar
Andy Kay
just to spoil you'r role stuart but dont you still use tar!!
and no i have never ever heard of a rim being damaged by tar .
also when you clean down your rims with turps also clean the pads with a light sandpaper that makes you'r brake awsome
i have grinds they are the way forward!!
cheers
chiz :blues:
Edited by chisholm
Tar does not damage the rim in anyway really, the thing that's more likely to happen is brake pads getting ripped off the backings and frame brake mounts getting stressed.
To clean tar off, the best thing to use by far, is Disc brake cleaner, either Muc-Off's or Halfords, well any will do. But yeah, this is an alcohol spray that completely destroys tar, and you just need to wipe it off with a tissue. It evaporates too, and does not leave an oily residue like white spirit does!
Pretty much ideal for tar-cleaning ^_^
cheers
chiz :blues:
or you could use turps to clean the pads and the rim much better than using sandpaper
steel wool works better than sand paper for pads and rim
