Grinded Rims + Magura Pads
Shadowfax
hey
you will have plenty of time BUT you really dont want to run the magura pads as my friend has them on the front and its got no power what so ever and i run plazmatic spanish flys on the front with a grind and koxx bloxx reds on the back with a grind and it is amazing. so much hold in all wether evan in the river!!
hope i was help to you.
cheers
chiz, :blues:
Seriously, do you guys drag your brake around " 'cause it makes a cool noice!! innnniiiit "
I've had koolstops on a harsh grind for 8 months, still goin strong, about 3-4mm of pad left... Another 6 months or so left in them!.... But they suck lol.
Wanting some Majics next :) .
Mat
Clean koolstops on a clean smooth rim with a well set up brake, and mabe a very slight amount of tar on one side would be fine.
i had bad luck with a grind a magura blacks and koolstops- a very sore ass can testify to that, and the wear rate was less than impressive.
hey
cheers
chiz, :blues:
you lie my friend, spanish flies are crap on a grind, i do agree with the koxx reds but still prefer my koxx browns. if you run the red pads make sure you only ride in the dry with the grind.
get a grind with some koxx brown pads or some heatsink blues.
Gavyn :lol:
