Rims For Harsh/going Big Riders?
planet-x-boy
Hello people. I am having some trouble with rims at the moment. I do alot of street and love to go big and the rims just cant take it. I have had a BMF, 2 koxx, viz and echo and none have held up.
I would like to no what rims damon watson and people that do very big street moves use?
Any help would be appreciated.
Thanks Brett....
The BMF/DX32 is the strongest 'cheese' rim out.
I suppose you could use a Sun Doublewide (Ali C used one, as did Whiteboy?), but I hear they're heavy.
I'd just try and be smoother, I've yet to dent my try-all...
i agree with janson my koxx rim really does rule, not asingle dent when i used to dent my dx32 a while ago (probbably due to grinded thin sidewalls and maby wasnt as smooth) but if youve got a good set of pads that work well on "soft" rims then your sorted. ive been using my majic pads on the same grind for almost 2 months and have had no need to grind they just hold nice. my next rim will be a onza hog only cause there eylated. or you can always buy my sunn doublewide off me with small flatspot...indurstructable ( well preety much)
cheers....
damon killed a sun double wall in summet daft like 2 weeks and is currently using a hog rim and apparently loves it.
also there is no way to land properly when goin big, ian hasnt a clue what hes on about, find sum big daft supid line that a few people have done, and look at it there is no way to land smooth.
Edited by Davetrials
totally agree. hard to be smooth on the first time on something big!
Hmmmmmmmm. That does help as i know how Damon rides. I have been thinking about a sunn double wide but might not bother. How long has he had the hog for? What are the ronnie undrilled rims like anyone?
Thanks Brett .....
coodnt say how long, but damon does sum fuggin big stuff, so unless you of simelar standard i think a hog or double wide would do u fine, i coodnt say anything bout the ronnie rims, i no there awsome to grind thats it lol
Just to let everyone know i am not at the same standard of riding that Damon etc are but i do like to go big.
http://www.trials-forum.co.uk/forum/index....showtopic=75905
That is a link to my under 2 week old echo rim after i drop gap. I am not fat or anything but just seem to go through rims quicker than brake pads and tyres lol.
Someone must be able to reasure me that there is a semi indestructable rim out there?
Cheers Brett....
I have the same problem right now. I've killed two '06 Echo rims and now a DX32(though it was drilled 1" so i'm not too surprised).
Can anybody tell me is there any real difference between an Onza Hog rim and a Koxx rim? Other than eyelets.
Damons hog has lasted for quite a while now.
His double wide lasted less than 2 weeks. Echos lasted less than a week.
His ronnie took quite a bit, but it has the un-drilled un that lasted.
Get a hog/v!z/koxx rim and get it built strong, thats your best bet.
Some people say grinds dont last long, but i've never had that problem. Try a set of Coustsinks with it for a good brake set-up.
I currently use an Onza Hog rear rim and its chuffin awesome :)(Y).... well strong had it a while now, and hardly flat spotted at all :-
the other uber strong rim ive used was the UNDRILLED ronnie ;)
sun doublewides are bollocks mine lasted like a week and a bit :ermm: and i didnt even drill it :huh:
Echo 2006 rim .......erm...... :lol::shifty::unsure:
planet x bmf was alreet for a bit, but 50'ped well easy.
conclusion: Onza rims are pretty damm strong.
dont even be tempted by Koxx/viz rims :sleeping:
