Tensioners ! ! Which One's And Where From ?
MOSH
Hi people, I have a King hub and am quite frankly P****D Off to the max !! I cannot find any decent tensioners. I have tried some Tryall Snail cams and they are S**T Slip and dont keep the tension and you can barely set it up yourself. I just dont understand how I buy a top quality hub and a good frame (Echo Team) and I cant get some proper tensioners. It makes me want to buy a whole new frame from the problems that have led on from this (pads rubbing, chain snapping) So any idea's on some PROPER tensioners that may work ? Ive also considered a half link chain but they snap far too easily. Any suggestions would be nice or even a bodge that will work. :)
Cheers Josh..
Stop being a wimp and tighten the bolts properly. Kings have massive fat bolts, which can take some serious beef. Mine never slip, and thats with no tensioners.
Or get fresh tensioners, work well according to guyeth my riding buddy.
Edited by Hobnobs
Where can I get them fresh chain tensioners from or the micro chain tugs you were on about ?? And yes Ive tried most BMX chain tensioners APART from weighing as much as my bike they dont fit !! :mellow: So Any other suggestions ??
............ By the way there may be a mod tensioner soon that everyone wants :blink: and DUCKO is all I will say :P
Josh..
snailcams mate, seriously they are the best for your setup.
do both wheel bolts up enough to hold the cams in place. then tap the cams with a hammer to slowly bring the wheel back so the chain tensions corrently. then tighten the bolts up a bit more, then hit snail cams with ahammer again. then fully tighten the king bolts :)
seriously, they rock, specially with beefy king bolts :)
Will
I think a few people haven't realised that we're talking mods here.....arn't we.
Anyway, i've never liked the look of smail cams, and the way they work, getting on ok with my chain tuggs even though i'm rounding off the bolts very quickly becuase i tighten them with the axel bolts are tight.
Get the beefiest bmx tugs you can, i would suggest some primo ones(or anything for around £5/£6 each), file them down to fit if you have to. don't get onza ones! there are poo i killed a set in a month.
cheers,
what dent?
by your brake mount spoonla' :P
thing is with a tensioner like that, id the brake might not align as well because the wheel will be closer in, but if it does then hats off. the only reason i has made one like that is so that my brake WOULD setup properly :)
anyways, nice work batman B)
Frame would be futher from the wheel you mean :-
