Light Weight Tensioner
Christophe'
do you have any videos or anything so i can get a feel for your riding style and stuff as i don't normally buy new frames so it best be like spot on basically thanks for the help and the speedy reply ill go and have a look at the pictures (Y)
nah, cos it buts up against the ridge in the mech hanger. and if it doenst it should cos thats how i'd make it.
its a local guy around here who makes them. ive seen a few being run around here, but have not tried one myself. they look like the worked really well, and yes they are preety light
Tell him to design one that bolts onto the axle, and do away with the hanger. Then it would be awesome. Although isn't there absolutely loads of friction there?
yeah, the plastic would need to be strong enough to push the chain down, but flexy enough to bend if it gets hit, and soft enough to stop it from being really noisy. nice idea though, i agree that you'd need to get an allen bolt on there instead of the phillips one.
yes i bet its light and yes it looks good but does it work well? also a surley or similar tensioner cant weigh enough to have to worry about it that much surely? i know id rather have a surley than one of them even though they are neater. and as for the weight, have one less pasty at a buffet or 1 less pint down the pub etc (Y)
Lets add an ally arm for more strength and a spring, just for fun aswell (Y)
Looks simple enough...Surley a chain would just rub it through in a matter of hours...Or if the plastic becam fatigued and brittle it would just snap..
That's why I mentioned having a roller there? :ermm:
