Buckal Problem?
matty allum
Yep, like he said, it's about pulling the rim over to the 'correct' side by either tightening the spokes on the opposite side of the wheel to where the buckle is, or by loosening the spokes where the buckle itself is. Use a spoke key, and remember it's clockwise to tighten, and anti-clockwise to loosen. Try and work in half-turns, and you should be fine. Just do it slowly, and check it as you go along.
well depending on how sireicouse the bucal is use a spoke key or a screw driver pal ? :blink:
I really don't mean to be rude, but you'll need to sort your spelling out if you ever want to get validated. Reading your post before you click the button, can you not spot the huge mistakes?
"sireicouse" - Do you mean Serious?
I really don't want to be seen to be bullying, but I find the lack of effort annoying - European members are better at English than most English users!
