Bedding In A Ck Hub
thewoomaster
Before you even ride it, take the axle & driveshell out, and blast the crap out of it with GT85 - you wanna get rid of all the white lube that's in there. Use a new/clean toothbrush too to help.
Then just go ride a few miles on it, plenty of up hills & down hills would be ideal.
Then clean it out again with GT85/toothbrush, let as much drip out as you can, then put it back together & ride it. :)
Works for me every time! (Y)
Take it appart and soak it in wd40/gt85.....after a ride do the same again ....idealy with a tooth brush...make shure its spotless and lube it up with a finish line dry lube ;)
WD40 would be a bad idea because it would degrease the internals and you'd effectively be running it dry. GT85 would be fine because it teflon coats everything you spray with it!
Wide based cog would be a good idea.
Phil (moose) used a standard cog on his King single speed and it started to dig in, not a problem but the fact that the needle bearings inside were disintegrating because of it wasn't cool.
Oh and I just rode mine when I first got it (3 years ago) did skip a fair bit mind. Is all good now though. but yeah wd40/gt85 and a toothbrush
WD40 has a higher oil content than GT85!
I'd strip it down into little pieces, clean the gunk out, and reassemble it with a really thin layer of grease on everything, like the lightest smear.
Do you even own a King? Grease in King = Bad.
It's been said a million times before. Fatmike's advice is spot on. Important to put riding pressure on it (but not trials pressure) so just riding about town is fine, just backpedalling it won't do nearly as much as riding. Riding also seats the bearings, so make sure the hub is tight every now and then when bedding it in!
Nope. I meant a smear as in, just enough to stop the insides corroding.
Aluminium corrodes.
It was just a thought! I would have expected it would be obvious that you should have a really small amount of grease, just like in a ffw. But whatever, it's your hub.
lol, it hardly corrodes on a scale that will affect performance, besides its protected by the anodising
Aluminium corrodes.
Aluminium corrodes so little.. A protective layer of aluminium oxide forms pretty much immediately when exposed to a normal atmosphere, which stops further corroding taking place.
Don't try and beat the engineer at his own game. ;)
For trials, Kings should be run on oil or dry. As we don't do a lot of miles you can get away with a hub that is almost dry. I use a bit of finishline wet xc, and it's fine.
Well there seem's to be alot of chat about lube etc.. So could someone tell me what lube is best?
So i dont want grease but a dry lube? :unsure:
A thin one with teflon mate. Like Mike said GT85 or that finishline wet lube stuff. Mine aint never skipped :D
Edited by max-t
