What Should I Do?
Sonny Clarke
To build or not to build
60 members have voted
  1. 1. Should i build my new wheel or get it profesionally done?
    • YES
      35
    • NO
      25
hey, i've read guides saying its an easy jobs and its not worth the 15 pound, but on the other hand, my friend says that i should definatley not do it as it is a complicated task that could go wrong.
I have a second hand rim and hub and new spokes and nipples waiting to be built but i am unsure on what to do.
Thanks for advice
Thanks for advice
Depends how confident you are and how much time you have :)
If you read the right guides its easy, more so with 32/36 hole 26" rims because you have loads of room to thread the spokes in, I taught myself on 48 spoke 20" bmx rims and that took a while :D
If you do go for it yourself then make sure you know all the mechanics of trueing a wheel, ie: how to get flat spots and bounces out of the rim aswell as getting it straight. Also invest in a decent spoke key that is the right size, Ive used a fair few different types over the years and imho the park spoke keys are by far the best. If you have a cheap spoke key then youre more likely to round off the nipples when tightening them and they also hurt your fingers more :(
Basically if you can see yourself building/trueing more wheels in the future then go for it :D
IMHO 15 quid for a wheel build is expensive, mine only cost me a fiver if I get them done.
Try building it yourself. I'm not a fan of rebuilding used rims but you can do it and it should be fine. I would never use used spokes though.
Like was said before you can always break it down and take it to someone if you mess up, or lace it yourself and take it to a shop to have it properly tensioned.
The poll question is an absolute disgrace ..... it doesnt matter if i respond with yes or no - you will be none the wiser ....
the answer is obviously - build it yourself ...
EDIT - and you can actually respond with yes AND no !! :lol:
Edited by manuel
:shifty:
i'd say building a wheel is complicated, until you get the hang of it. I've never built one myself, but i'm prepared to try at some point. Just read the guides, make sure you have some idea of what you're doing, and take your time.
