Dob 26"
UrbanLegend
So, here she is... Pretty much finished, might consider a lighter front hub in the near future, but otherwise I'm chuffed with the spec! Rides extremely well :)
Quick spec:
DOB frame & forks
King headset, carbon topcap, Ti bolt, carbon stackers
Tensiles, Trialtech bash, Ti crank bolts
Wellgo MG-1 pedals with Ti axles
Thomson stem with Ti bolts, old style Zoo risers, Rock foam's
Front Mono Trial with Unex rotor, Ti rotor bolts, Ti caliper bolts, Ti lever bolts, Carbon lever blade
Rear HS-33, Ti lever clamp bolt, Trialtech booster, full Ti hardware
Front Mavic X317 Disc on Hope Pro 2, Ti skewer, Latex tube and Tryall tyre
Rear Tryall rim with inner wall removed (single wall) on Chris King BMX with Ti bolts, standard tube and Schwalbe Big Betty tyre
Tryall snail cams
KMC Kool narrow
That's basically it! Weighed at Mud Dock... approx 8.7kg! Without taking a drill to anything (apart from butchering the rear rim!)
Comments appreciated as always
Edited by UrbanLegend
It's definitely more flexy than a Deng frame... But it's so flicky and light, you can't really notice!!
I won't be getting Mag rims, mainly because my front rim is far lighter, and the rear isn't far off having had the inner wall removed! Plus it can hold a grind a lot better!
Been thinking how it could possibly be lighter, without getting silly with weak parts... I don't like front freewheels, and to be fair when I worked everything out, the difference in weight was tiny (I saved a fair bit changing to Ti bolts on the King!). Also front disc to a V possibly... But not for me.
Any ideas post them up!
Cheers for the comments chaps :)
Max - I'm looking around for front tyres, just finding something lighter than the Tryall that isn't a hard compound seems tres difficult (N)
Very nice.
How do you go about removing the inner wall from a rim?
Used a grinder first, tidied with a Dremel and file :)
