It Works For Me
Everything surged from something I heard that happened at the koxx days 2008...
It appears that in one of those days (Saturday) Gilles Coustellier cut out the knobs of his tires, Vincent saw Coustellier's tires on Sunday and he did the same thing on that day
So I decided to do the same… :)ALIVIANEMOS.jpg
Edited by chrisTrial-arg
*Cough numpty cough*
Actually no, it does have other benefits. I've done it to my tyres too, apart from saving weight (its saves hardly any though), they tyres shed mud more efficiently and also (I'm taking bessell's word for this) they grip better. I couldn't tell you if they grip better or not because I swapped from Schwalbe to a Maxxis, hacked away at the Maxxis before I'd even ridden it. But what i can tell you its that it grips very well how it is.
Edit: Did you actually cut off all the nobs on your rear tyre? If so, the word used to describe you above was probably accurate. They cut every other nob on the outside rows of their rear tyres. Any more than that and you must have a death wish. I think Giacomo Coustellier might have cut all the tread off his front tyre (bit daft IMO)
Edited by Quackers!!
i removed some tread from my maxxis hansventre as the tyre seemed to me a dog poo magnet ,once i had removed some of the tread it wasnt.i've also removed everyother block from the side tread on my front highroller.
maybe christrial-arg has taken too much tread of ,but surely he is only experiamenting and theres nowt wrong in that.
steve
the only way it could offer more grip is the same way slick tyres grip better than knobbly tyres. Only thing is, they need to be warm and normally slick tyres aren't used for going up walls, where they might slip. Also, roads and what-have-you are smoother surfaces with less stuff to contaminate the rubber.
I'm keeping my knobs...
er, tyre tread.
if they gve better gripthen, well, why arent they manufactured like that??
Because companies like Maxxis don't make trials tires, they make downhill tires.
er, tyre tread.
No. Got a spare tire to hand? push the tread in a bit and you'll see all the knobs get closer. If there are a few less knobs then an edge of a knob can grip the edge of something better. Otherwise its like having a nearly slick tire on the edge.
because the tire can fold over an pinch the corners of objects easier.
Oh, I see.
I guess that makes sense, fair enough.
well i dont really see he point in this i think it is not worth it to be honest you dont loss any weight
well thats my point of view diff people have diff ones
greg
Well you're losing part of your tire, so you will be losing weight.
And it adds grip, so there are good points to doing it.
Edited by froob
That much? I'm doing it.
I doubt it would be much more, think about how many knobs could be cut off if you did every other one on the side knobs.....
Gotta be like 30-40 knobs?
Can someone count how many knobs they have for me?:P
