Tar's Replacment?
Matt_Thibeau
So i couldnt sleep the other night, and i was wondering what could be somthing cool for my breaks, and then i wondered what would happen if I aplyed a tad bit of honey or syrup to my rim, its sticky like tar and easy to get too. So in the mourning i whiped my rims clean of tar and grime, and apllyed a little, it works great!! super bitey and doesnt seem to wear out! it has a awsome sound too! So just as a experiment, give it a go :P Im not too sure if anyone has tried this though!
Matt Thibeau!
I bet Ryan Leech uses Maple Syrup... :P
Given that honey is water soluble I'm guessing that at the first sign of wet the braking will disappear though, probably no worse that tar, but given a grind needs less minding and isn't as sensitive to the wet for the Irish/UK climate there is no other choice for me...
I went through a phase of using tar and other things like hairspray, if you use it though i would say you must be careful not to over apply it. often my pads would stay sticking to the rim.
I always use a grind now, mainly because it doesn't increase the ability to become sticky (thats what a good set of pads is for) the grind just increases the friction between the rim and pads! which i would say is more reliable and predictable then using other sticky substances.
in a quick fix i would say use hair spray, quick and effective, but don't last long!
