Nicest 24uk ?
spaceman
I was using the shadow conspiracy bmx seat, but the rain water always get soaked into the cushion, so I stripped off the cushion. It's "lighter" and has a more "carbon seat" look. Lost my 74kingz tensioner, it just dropped off :( So I'm using a cheap da bomb tensioner now. I changed to Maxxis Holy Rollers too, feels so much more nicer than the k-rads (I find them too thin and hard). I also got my one of the 4-bolt mount heli-coiled, but the rim is too narrow to use the 4-bolt clamps. The evo clamp is good for now.
Some changes coming soon:
Echo forged black crank. The current crank fitting got loose, tried the coke can shim but didn't work out good.
18:14/15 ratio. Currently is 21:16.
Trialtech bashring. Onza tensioner. dx32 for rear. tensile clamps.
Comments please :)
(I would get the hose shortened when I'm free :) )
Edited by spaceman
It haven't slipped on me yet, but I'm not really good at giving reviews on tyres.
I like them cos they're nice and wide, and better than Kenda K-Rads (which are abundant in my country), no LBS wants to bring in Holy Rollers.
Pinched twice (many times on k-rads), but i was running quite low pressure then, around 25psi. K-Rads also have very thin sidewalls which tear easily.
Do they ever pinch?
I know there are some "anti-pinch" rims, but are there such tyres? And I'm using 1.9'' tubes cos 2.3'' tubes are very rare for 24'' here.
Edited by spaceman
Holy roller, what are them tyres like on the rear? Do they ever pinch?
Any tyre will pinch if you rim it hard enough.
Whatever you run, you want a good, thick innertube in it, like the kenda one or the halo one.
This bike looks pretty sick, I like the blue.
The bars make it look quite bmxy lol.
Edited by Revolver
Well, soon no more blue cranks, but black, haha. At first many didn't like the blue crank, which I thought so too, it kinda spoil the look - it stands out too much.
Only my bash would remain blue.
  • 1 month later...
I've changed my cranks to Modulo, which is a local brand at my side. One thing good about the Modulo crank is that a threaded shim gets screwed on to the crank, then the sprocket, in the event you strip the threads, you just have to replace the shim. The mechanic who was also a masterclass rider said that those cranks were "indestructible" and very stiff. Riders at my side have been using it for 2 years and none of them suffered from any stripping yet. I've also gotten a Trialtech bashring! I can say it's the coolest thing on my bike :D I've also gotten a proper single-arm tensioner, by Point Racing. The ratio is 18:14, and I'm still not so used to it yet, it's a bit lighter than my previous ratio.
I got those new parts from the local trials shop, and when the mechanic fixed it up, he said that my BB had warpeda little, and my dropouts were a little slanted (due to the flex). He also found out where the creaking sound was from. I thought it was the headset, but he showed me a crack on the fork steerer where it bonds with the crown. Anyway, here are the pics. Can I say it's one of the nicest 24UK around? >_<
I am not a total fan. I would like it more if it had a longer stem and if you were not using EVO mounts. I hate maguras with evos.
how comes you're using the V mounts for your maggies??
steve
I might try out a longer stem, I would have to admit the 24Uk has quite a short toptube.
