Spraying A Laquered Ali Frame?
eskimo
I've searched all sorts on this but have no idea where to start still. Read the wiki & used search with many a phrase. Plenty of info just nothing that applies.
I'm trying to spray a polished aluminium frame, like your regular Echo Control or Lite. Just they are lacquered but i don't know what i should be doing to prep one.
Any help on the removal or prep of this would be great.
And if the original Wiki editor on the 'spraying article' would update that would be great for future users, as it's a pretty good one already.
Ta.
Not really keen on any sort of blasting of my frame. A light one would probably be okay, but i can't be bothered with spending the money on it anyway. The lacquer is fine i guess? There is some damage and maybe some raw areas about, but i've two cans of Hammerite so i shouldn't need to primer it? Though i do have a tin of Hammerite Primmer for raw metal anyway. I have several sheets of 1200 wet & dry (i think it is 1200) i'd have to check.
Thanks.
Thanks.
PAINT THINNER AND ELBO GREACE!!!!!
Either that or acid dip the frame?!?!?
Just sand it down by hand, lacquer can't be that tough to sand through? Just roughen it up a bit, doesn't all have to come off I don't think, as long as the paint has something to stick to then you'll be sorted.
As said above, use etch primer!
Checked with my mate who works in a body shop. Just key up the frame with a bit of wet and dry to give the primer a surface to adere to. A normal primer will do the trick. then give it a few thin coats as sed previously and allow to dry properly between each coat. once happy that the paint has hardened use the wet and dry again to smooth down the primer so your top coat will have a good finish and again something to adere to. and the same process for putting laquer back on top of your colour. hope this helps if you need any more advice just drop me a text
funnily enough i just sprayed a frame at college.
First- Take it back to metal with a 320/ 240 grit sanding paper
Second- Go over it with a 500 soft pad to make it smooth
Third- Spray on some etch primer ready for the actual primer
Fourth- Spray on your High build primer (2 to 3 layers =] )
Fith- Spray on your base coat ( what ever desired colour )
Lastly- Aplly 3/4 coats of laquer. If you want it shiny leave it like this or
if you want it to look matt then go over it with some wet on wet paper :)
Hope this helps dude, this is how you spray an aly frame as i just sprayed my frame on my course at college and
it looks awsome :)
let me know if you need any further help (Y)
