Gearing Ratio :s
jim-p
Hello people
I would really like to know what 16:10 gearing would be like
but i dont want to waste my money on it and find out it is Sheet
Could anybody shed any light on this; in form of a comparison to a 18:12 ratio
or something like that
the biggest help would be if the people who have experienced this could tell me
but any help would be great :)
thanks people
Edited by jim-p
Well, I'm currently running 16 rear, 22 front. That is crazy heavy for me, and although gives the speed to get up some objects, restricts you on many other moves.
I'll be going to 18 soon - which I think is ok. Anyone want to help me out here? :D
22:18 is fine mate, should work pretty nice...supposedly comparable to 18:16?
It's great for BMX style stuff, or attempting to get up bigger stuff that needs run up (big for me anyway) - but it's SO heavy for small stuff.
18 shall be ordered on the 27th! Cheers man! :)
Also a smaller front sprocket means higher chain tension to transmit the same torque from the cranks - going from an 18T to a 16T front sprocket increases the chain tension for the same pedal load by 12.5%... Going from a 18 to a 22T drops it by 18%. This is why you can get away with 8 or 9 speed chains with a 22T chainring (If you're careful), but on an 18T chainring having the chain snap is nearly certain unless you run a BMX chain unless you never do gaps.
Remember that a 10T cog has less than 5 teeth carrying the whole load from the chain, so you'll get plenty of premature chain and sprocket damage compared to say a 15T cog where 7 teeth (40% more) carry the load...
Edited by psycholist
