Pro2 Hub Shell And Profile Internals?
RossMcd
  • 2 weeks later...
Doesn't work without quite a few custom parts.
Thanks for clearing that up adam :)
bumping an old topic
I have just put my profile axle and freehub body into my pro2 shell and it seems to work
i have also used the profile drive side bearing and the other bearing is from the pro2
the only thing i cal see will need modifying is the end cap on the non drive side wich will have to use the pro2 one, wich means you mont beable to use disc unless you can file the profile drive side one down but there is only about 3 mm that you would be able to file down :/
understand?
but tomorrow im goin to cut the end cap down and get it into my bike, if it works ill get some pics up and pictures on how i did it step by step :)
understand?
Safe I wanna see :D
Ah man thats pretty cool! you need to get the pics up like! How does it sound? And once you have tested it give us a review like! ;)
just got a couple of pics for you as it stands
tomorrow im gonna try and get the pro2 springs and pawls in it as they are wider than the profile ones so might be alitle stiffer if you get me if not pawls then i will just put the springs in as they are alittle more quicker?
pics
(sorry for quality they was took on my phone(ment to be 8mp :S))
EDIT: sorry for spelling im tired :P
Edited by Daniel C
It'd probs be easyer just to buy a pro 2 and cut the axel and driver shell down, aparently it didn't take that long and wasnt that hard.
I dont think it would lol when i took the bearings out the freehub body of the pro2 there is a little drop if you get me? the bearing would only sit were it already is so when you cut the freehub body down that bearing would have to go, then i think there would be too much force pulling on the freehub body resulting in snapped axles and exploding bearings lol
if swindle could tell me how his was done then i would do it but i really cba thinking lol.
Steve did it and danny bought it off him, he milled down the drive shell and got it re tapped, also cut the axel down and abit of the disk mount I think, dunno about the mount bit though.
I'd rather work out how to do that rather than buy a pro 2 and a profile and hope for the best lol.
Well actually if you already have a profile and you end up cracking or damaging the shell somehow.. You can easily buy a pro2 hub shell off tarty which are now available and put your profile internals inside. And now its been proven to work, people are now going to consider doing it.. Meaning more baby Pro2's floating about :)
oh dear.
or you could just buy a new profile shell for cheaper. keep the same rim and spokes you had previously, and save yourself money altogether.
why do some people make it more complicated than others.
if you want a 32h, buy a FFW and get a new rear wheel. Which will offer a lighter set up, and generally you will become as good as gilles coust.
oh dear.
lmao, just what i was thinking, the stupidest idea ever, the only reason pro 2s are good because of the pawls and springs, and u'd be running profile ones, its just pointless getting new spokes and rim, when you could just get another profile shell, both profile and pro 2 shells crack so i dont see the point, unless you wanted 32h, but you can get dx32s in 32 and 36, echos in 32 and 36 and try alls in 32 and 36, so you have any option.
Edited by Mat Smith!!
Update with pics of it in my frame :)
me and callum curwood was playing about with it last night and got it into my frame,
pic :)
here is what we did to make it fit and work
1. take the axle, driver and drive side bearing out of the profile, along with the end cap
2. pt all of that into the pro2 shell leaving the non drive side pro2 bearing in(im guessing the profile bearing will fit)
3. cut down the non driveside end cap of the pro2, all you need is the little silver bit on the end of the cap.
put that onto the end of the axle.
4. and then put it into your frame :)
The snail cams also work on the inside of the frame :)
problems(there are always problems lol)
1. the non drive side snail cam bolt head will have to be filed down about a mm if that, so that the wheel can go more forward as it hits on the end of the hub shell
2. there is no seal on the non drive side so im guessing if you like to get your bike dirty you will go through bearings lol, but you could probilly get a cover off a non sealed hub.
Thats about it really, im going to get it built into a wheel asap and ill get testing it :) i shall let you all no how it goes :)
pic :)
Looks, and sounds like it's gone pretty well mate (Y)
Make a vid after you've built it into a wheel ;)
For it to work with a disc, it needs the proper end cap. (Or a new one machined designed to work with a cam).
Really good work so far though, hope it works properly. I'd still much rather have a shortened Pro 2 drive shell and axle though.
