Jammed Piston Lever
bikeperson45
Okay, I used the syrine kit and kept the lever bleed hole done up and pumped water through from te slaves, which didn't get the piston out.
Than i tried it reverse order and taht didn't work and then the normal way.
Is there anything else i should be doing?
Thanks
Yeah, not that. Take the lever off, whack the syringe on and blow air into it
Me too, this only seems to happen when people use water instead of some kind of oil, the piston doesn't get lubricated and just gets stuck. Mine took an almighty force to get it out and never worked again.
To be fair I used the same lever body for years and years, and got it 2nd hand anyway.
Water still acts as a lubricant. You also have about 30ml or so (at most) of fluid in your brake, which is spread over the entire brake system - how much fluid do you think is actually used to lubricate the system anyway? The vast majority of it is plastic hose, and the rest of it should be suitably lubed by the water itself passing over it. It seems funny how all the problems people have 'because of water' I've had with oil bled brakes too...
To the original poster dude - if it's waterbled, are you sure it hasn't just frozen?
Get a vice (or a helping hand),
take the lever blade off, get some long nose grips, clamp down with both hands onto the edge of the piston,
get someone to fill a syringe full of water, don't use air as it compresses and you have less force,
whilst you try pulling the piston out, get someone to push water through with the syringe,
If all fails, I have a silver lever body you have borrow, which has a piston in it already. :)
Me and my Dad tried that and no success :( Think it's wrecked but gonna send it to Tarty and see if they can do anything.
I'm alright for tomorow, haven't sold my Koxx yet so will be on that, thanks anyway
