Trialparts.Net And Zhi Z3R Frame
Canardweb
ZHI Z3R geometry: Wheelbase 1080mm, chainstay 385mm, BB +60mm, warranty 6 months.
Bionic B5R geometry: Wheelbase 1080mm, chainstay 385mm, BB +60mm, warranty 6 months.
That CS length is incorrect, it has to be 380 because there are no gear ratios that will work with 385 horizontal.
Sort of - in the usual joyous way that no trials companies use a uniform measuring system (most are even inconsistent within their own range of frames with how they measure them), it could be that it's 385mm from the centre of the BB to the start of the dropouts, meaning that it would end up putting your back wheel nearer a Stinger-ish 390mm.
  • 1 year later...
