Inspired Tensioner?
Paul pedal whore
Rohloff on my Fourplay. I couldn't get the pin off for all the love in the world, so i just filed the mech hanger to allow for enough rap with a 13T sprocket.
I regard to taking the pin off, I did it by holding the pin in a pair of pliers (but you could use a vice) and using a cheap pocket multi-tool that had a screw driver set that included some Torx attachments. Don't know the exact size but it is slightly smaller than the ones used as disc brakes rotor bolts.
Edited by AndrewEH1
Yep, that's what I did. I have the correct hex size and no matter how well it was clmaped it didn't want to come free. It's as if the pin was bonded on. It doesn't matter at all, the hanger mod only takes a few mins and i've never landed on it so all is well.
There was some bonding on the bolt when I took it off, guess I'm just more manly than you, or I got a badly built one...
