The Worlds Lightest Disc Brake. I Jizzed :)
Laurence--Trials
An ultralight hydraulic disc brake from KCNC featuring a remote radial master cylinder lever, kevlar reinforced hoses and callipers with cooling fins. The brakeset combines to give a race ready system at 250g front and 263g rear including 160mm disc and calliper bolts.
Hydraulic system rated to 8000psi
Reinforced kevlar fibre internal mesh braided hose
Ceramic / metallic compound alloy backed brake pads
Reversible lever for left or right fit
160mm stainless steel Razor rotors
Weight : Front lever, hose and post mount calliper 169g
Weight : Rear lever, hose and post mount calliper 185g
Weight : 160mm rotor 73g
Total front : 249g (inc. 2x Ti calliper bolts + lever, calliper & rotor)
Total rear: 263g (inc. 2x Ti calliper bolts + lever, calliper & rotor)
Total set : 512g (all weighed on our scales)
Set does not includes any rotor bolts.
Annnd... this is me now :)
  • Like 1
Saw the BrakeForceOne thing the other day on singletrack and went looking for a price, the cheapest I found it for is about 340 quid.
That was from here.
If they are as good as they're claimed to be may have to invest.
Please tell me that price is for a pair and not just one...
Edit. Ok it is just for one :mellow:
Edited by Jake-Ansell
As far as I can tell essentially it's a smaller piston moving the larger piston to the rotor which then engages for more stopping power. That means you can have the power from a large piston but no issues with brakes rubbing all the time like you would if it were a brake with just a large piston, or the other way round if it's in the lever.
Sounds like it would feel a bit mushy and weird.
Edited by ZeroMatt
