Dirt Jumper
robmod
orite guys as the title says this is about a dirt jumper ive just got my back wheel sorted and ive got a tensile 18t freewheel kicking around so ive decided to put the on my rear wheel what front sprocket should i use teeth wise?
i run 25-9 on my bmx so its probably 50-18
Remember the lockring is designed to tighten when its used as a front freewheel ( so on the rear it will tend to loosen and spew its respective pawls and springs all over the floor ). You could either try some heavy threadlock, or weld it which I did for my dirt jumper :)
Surely there's no difference ie turn it clockwise the freewheel will lock turn it anticlockwise and it will spin. Fail to see how it makes any difference if it's on the front or back.
