External Bb's How Do They Work?!?
CriminalTrials.co.uk
That's because the axle is attached to the cranks!
I don't completely understand them myself but they seem to work great!
You'll need new cranks if you want to use this type of bottom bracket go with some Shimano or Truvativ ones.
Edited by AndrewEH1
The axle's on the cranks. There's a bolt that pulls the cranks towards each other, onto the axle. There's a hat-shaped washer that's usually on there to make sure the cranks push together right - without it the cranks crush the bearings when tightened.
It's called hollowtech II I think, so you need some hollowtech II cranks to go with it, or a new BB and matching cranks.
Thanks for the info guys.
So the cranks are simply push fit still but no bolts? how do they stay tight?
They work in the same way as 2pc bmx cranks but instead the bearings screw in like a standard bb all you need to do is slide the axle through the bb and then put the other crank on and tighten, at least i think thats how it works.
link not sure if this will help?
Edited by bike_dummie
  • Like 1
i do believe that echo also offered an external bb system, supplied with an isis axle, allowing you to run external cups with normal isis cranks. The advantage of external cups is that the load is spread more evenly, and the pressure from the crank turn is closer to the bearings, so the effect of leverage is reduced.
I run the Shimano Hollowtech external BB system for trials, and I don't think I will ever go back ...
Damned right ! Running a cheapo Deore crankset and X type BB on my street bike ,superbly stiff and a doddle to install. Kinda tempted by the Saint cranks though.
External bottom brakets are the way to go these days on new Mtb and Road bikes. Road bikes have already superceded the external bottem braket and some companies now run large size internal bearings with a propritary crank. Never thought about using them for trials. You could make it work you would just have to find a crank that runs an axle meant to run with external bearings. Axle just needs to be the correct length and diameter so that it works with the BB. Might take some jimmy rigging and some trial and error. Ceramic BBs have very little friction. A ceramic bearing BB crank will spin effortlessly compared to a regular shimano non ceramic BB. That echo setup looks pretty good. I had bad luck with echo brakes though.
Happy Valentines Day!
Edited by Philly_Biker
Screw thread with a lockring, or some kind of washer that tightening the crank would push into the bearings. That second one would work better with ISIS I think.
Hm,it might work,but ot would be a lot of work for what it is and tolerances would have to be very tight(or spacers really thin,like 0,2mm I guess?).
