Helium
dan rider g
there are better ways to waste money, if you'd like you can pay me to tell you not to be a dumb-ass every time you have an idea...
it will make a marginal difference at best, and would only be worth considering once you've exhausted all other weight saving options and have the lightest possible machine already... my googlings also suggest that helium particles are smaller than air particles, so your wheels would go flat faster, so you'd need to top up the helium frequently... d'you recon the wheel would perform different at the same psi of an air filled wheel?
also, it's spelt 'idea'
helium would escape through the tyre because its such a small molecule,
thats why a rubber balloon filled with helium starts to fall after a day or so.
racing cars use tires filled with nitrogen (also The latest Nissan GT-R)
but thats because oxygen is considered "too unstable"
The nitrogen keep in pressure however you run the car
but!!
It is very hard to get a vaccum in your tyres to do initial nitrogen filling...
and it costs at lot to get to 99%.
soo..
try it and tell us how it went
and remember The petrol air pump is 78% nitrogen :wink:
Edited by alanczik
  • Like 1
i thought thats enough for most comp rider to try it out... :dance:
Sadly, it probably is! Haha.
There's still this as the major problem with the idea though:
