best tubeless tyres
Ash-Kennard
recently bought some stan's flow ZTR crest rims (naice) and i dont really know anything about tubeless. do i just need the super tight rim tape and a valve and no sealant because they are tubeless ready?
also, been looking for some decent tyres. got my heart set on maxxis, after using mountain kings and rubber queens, i feel maxxis will be better. I ride this bike around a local trail centre relatively often but find my front tyre slipping out on me a lot. irritating. but yeah tyres need to roll quickly, grip well on corners and cope with mud from time to time. and of course be tubeless.
i have also been looking into UST and LUST but can only find high rollers which i found to be pretty slow. and ideally want to try a LUST minion. found one in america, but no luck in the UK any ideas?
cheers, ash
You can use maxxis exo tyres with some Stans sealant, I have setup loads of xc/am bikes riding in the peaks with exo ardent 2.25 rear and highroller 2, 2.4 front.
If the high roller drags too much for you then a minion exo not be better for you on the front
I Soo look tmz if there are lust versions of these avalable
You will be better of running the sealant thou to seal thorn punctures that lust tire will still get.
  • Like 1
ust and lust options here for you
minion 2.5 ust http://www.cyclestore.co.uk/productDetails.asp?productID=26814&categoryID=8262
ardent 2.25 lust http://www.cyclestore.co.uk/productDetails.asp?productID=26827&categoryID=8262
the point of tubeless for xc is less rubber so it uses less energy to deform the tyre as it rotates. and because the tyre deforms easily it also grips better.
and rolls more eficiently, it probbably is hardly any difference.
to me its less punctres less pinches, lighter than just the standard tube (if you use exo tyres not ustits lighter)
if you use ust with sealant you wont get any punctures or failures. unless you rise through a bottle bank or knife factory
Specialized or Bontrager tyres. Both are tubeless ready. Ive been running a Specialized The Captain rear and Ground Control front combo for a few seasons now, as an XC/trail tyre. Sweet at trail centres too. For more grip then swap the Ground Control to the rear, and strap a Specialized Purgatory to the front. Win! :)
hmm i hadnt even considered them, they do look pretty nice. defo one to consider
  • 4 weeks later...
just to let you into a secret, pretty much all decnt tyres will hold air for months with them rims and a bit of sealant, iv got the stans rims on my orange, i did start off with ust tyres but then tried out a normal runber queen on the front and it held air fine, at the moment and for the last year plus iv had a conti vertical pro traction normal folding tyre on the rear. nice and fast and only about 600 grams
they roll alot better than normal tyres with tyres even if they are the same weight
  • 2 weeks later...
Normal tyres will go tubeless but the side walls are very thin and will be subject to tears of rocks.
Back to my 1st recomendation that was ignored. Maxxis do the exo tyres, lighter cheaper and work on tubeless setups. But have stronger sidewalls for the purpose of Stans tubeless setups.
Rim only I take it? You'll need the stans tubeless rim tape and yes it needs to be pretty tight on there. Definitely run latex (stans stuff is great) and you'll be forever happy.
I've found the Continental Barons to be pretty excellent but are expensive if you want the proper UST ones, but i've been running the cheap cheap ones at 17 quid a pop at retail and they've been fine. My folding Rubber Queens had a lot of trouble running true with my Flows so I would either go UST or cheap wired.
