Gym - No more weights, what to do?
dannytrialskid
I have been speaking to a couple of people about my arm pump.
Ever since I have started weight lifting, which has now been about 2 months I have got very bad arm pump when riding.
So bad that half way through the first section on the first lap of the last 2 comps I have entered my arm just pumps up so much I can't complete a section in the available 2mins30secs due to trackstanding to try and get the blood flow back to my forearm.
I have been told to stop weight lifting, which I am fine with doing. I only done weight lifting, because I wanted to gain strength for trials.
So that been said, the gym is the cause of my severe arm pump issues and have been told (as I said above) to stop lifting weights and to also create sections when I am practicing and try to get through them in the 2mins30secs which will help.
So after this long winded repetitiveness I have written above. What should I do at the gym? I have a one year membership there and can not leave unless I buy my self out for a stupid price. So I may aswell stay. I will work on my core and do some cardio, but is there anything else?
What could help with the endurance of my muscles without lifting the weights?
Thanks in advance, Danny.
Im doing a 12 week programme. Week 1 low weight 12-15 reps. Week 2 up the weight a bit and 9-11 reps. Week 3 up the weight again and 6-8 reps. Week 4 up the weight again and then 3-5 reps. Repeat 3 times, which makes the 12 weeks.
Monday - Chest/Triceps/Calves
Bench Press 4 sets
Incline Bench Press 3 sets
Incline Dumbell Flyes 3 sets
Low Pull Cable Cross Over 3 sets
Triceps Press Down 4 sets
Skull Crushers 4 sets
Cable Overhead Triceps Extension 3 sets
Standing Calf Raises
Leg Press Calf Raises
Tuesday - Back/Biceps/Abs
One Arm Dumbell Row 4 sets
Wide Grip Pulldown (lats) 3 sets
Standing Pulldown 3 sets
Straight Arm Pulldown 3 sets
Barbell Curl 4 sets (2 sets close grip, 2 sets wide grip)
Incline Dumbell Curl 3 sets
One Arm High Cable Curl 3 sets
Hip Thrusts
Crunches
Dumbell Side Bend
Wednesday - 60 minutes cardio
Thursday - Shoulders/Traps/Calves
Dumbell Shoulder Press 4 sets
Side Lateral Raise 3 sets
One Arm Front Cable Raise 3 sets
High Cable Rear Delt Flyes 3 sets
Dumbell Shrug 4 sets
Friday - Legs/Abs
Squats 4 sets
One Leg - Leg press 3 sets
Leg Extensions 3 sets
Romanian Deadlifts 4 sets
Leg Curls 3 sets
Crunches
Hip Thrusts
Plank
Saturday and Sunday - REST
The last set on Week 1 and 2 of the month is Rest/Pause and the last on Week 3 and 4 of the month is drop sets.
It is kinda extreme when you look at it for a trials routine, but I did want to gain some size too. However I can now see it's not worth it as I'd rather be able to ride my bike without arm pump than have big(ish) muscles.
I do wear gym gloves on my routine.
Edited by dannytrialskid
As Liam suggested, if you're doing something that requires grip every day, it's no wonder your forearms are complaining. Any time you have to heave a weight around you use your forearms.
Maybe you want to take a week or two off and then change your routine to one with more rest days and less in it.
This is ridiculous. You're getting arm pump because you haven't conditioned your body to last as long as you need to! Not because of weights.
In fact when I started deadlifting it utterly destroyed my grip. Left me fumbling with my fly for ages desperately needing to urinate actually
I suggest you give yourself the proper rest and stick with the weights
  • Like 1
Where would I get more rest though?
I could try and get one more day rest out of it by combining some of the workouts together.
Monday - REST
Tuesday
(Include my core workouts here?)
Thursday
Friday
Squats 4 sets
Leg Curls 3 sets
Bench Press 4 sets
Would this be better? Have taken some stuff out too.
Would you suggest anything else to take out?
I just did every other day as a rest day, even if it meant training on a weekend. Like so:
Bench Press 4 sets
Tuesday: Cardio/rest
Wednesday - Back/Biceps/Abs
Hip Thrusts
Crunches
Dumbell Side Bend
Thursday: Cardio/Rest
Friday: Dumbell Shoulder Press 4 sets
Saturday: Rest/Riding
Sunday: Squats 4 sets
Leg Curls 3 sets
Bench Press 4 sets
Then Monday starts as a rest day and so on.
Ok, I get it now.
So the days are different every week caus of the odd number. Got a little confused. I'll try it, thanks.
Edit: So you put in chest and tri's for twice a week?
And, do you reckon I should give like a week break before trying this out. So that everything is fresh and relaxed, that way I can see whether it has made a difference?
By break I mean just cardio and abs.
whats the point in doing all those slow motioned exercises when trials is a powerfull movement involving fast movements?
creatine you need to increase your water intake as you will get dehyrdated loads quicker.
This will sound silly, but I'm not sure I know what arm pump is hah!
That being said, are you sleeping enough?
If you are going to the gym and do bodybuilding type routines, you will be destroying the muscle fibres and you have to give the body lots of sleep to rebuild it.
I work out at the gym for a few hours every day and I go to bed at around 10 pm (9 pm UK time) and I get up at 6 am.
So try sleeping more!
Kevin.
Kevin.
I sleep at 10.30pm and wake up at 6.15am
Sleep is very important with your training! As Ozzy said above if you are mainly training to improve as a trials rider, explosive movements will really help. Plyometrics, Deadlifts, Clean and press, sprinting is a good one which is often overlooked. You could try a good cross fit class which will incorporate a lot of explosive, high intensity movements. One more thing to think about, most trials riders (myself included) we will do one move stop for a few minutes, then do another. If you want to improve your arm pump you need to create sections which will last longer than a general comp section and just push your threshold. So when you do go to a comp you know you can ride for that length of time without getting the pump.
I'm on mobile so I cant read the thread in work to see if anyones suggested what I'm saying here... dead lifts will help your grip/forearms so will rowing; especially if you grip the row-bar with an open grip; fingers only no palm on the bar... will flare up your forearms in no time... I row/pul up/deadlift regularly as balls and havent had arm pump issues in time...
How many reps on Deadlift and sets?
Anything in my routine i should take out? I only want to do stuff that helps with trials
