gap to big
george5353
Basically the slave collides with the sides of the mount so it won't go in any further. Tarty do a pic to show you, where the hose goes in at the top thats where it collides mate!
So essentially you get the same amount as inward clamping as any other mount.
Edited by dann2707
  • Like 1
Having brake pads with more meat on them will only sort the issue temporarily. The pads you have on there have loads of life left at the mo, so if they're not hitting the rim enough then you'll only be able to wear new pads down to the same level before they become useless. A wider rim would be a far better bet and you'd be able to run a set of pads for more than a third of their expected life...
