Et24 Updated
kerley
I seriously think I have the worse looking ashton on the forum (not for long though)
very nice dude, needs better tires though!
the best 24" tires i have found so far
Front - DMR MOTO DIGGER
Rear - MAXXIS HIGH ROLLER 2.5
What length stem are you running on it?
Mike
cheers for all the comments guys.
the grips i'm running are the big cheese hard and soft grips which are holding up really well and feel great.
Is that a hope stem?!Hows it holding up?Light?
I am using a 90mm*10 degrees rise hope stem and its the best feeling bar/stem setup i have had for a while now (not that there was much competition)
I am currently looking for a lower seatpost so if anyone knows of one then that would be brilliant.
*cough* BMX *cough* You know I love it :) Looking nice now :) Better saddle and the bore cap change, did you need to bleed it for the change?
James :)
p.s. Kerley I can gap further now :) Pompy here we come!
I'm not sure if i needed a bleed when i had the bore cap changed but i'm pretty certain that it would have needed to be bled, even if i didn't have the hosing changed at the same time. Ask Dave from Tartybikes as he did the work on it.
