Kot Frames
lewis
I'm think about getting a kot frame but only if i can fit a 205mm 6 pot ti on it. does anyone know if you can?
wow! crazyness!
why would you want to fit a 200 mm rotor on there, especially with a 6 pot brake :D
is it because u have this brake already? or because u want the most powerful?
because i would've thought a mono trial 180 would be plenty (Y)
get a 180 mono trial - but why a disc for the back ???
better for trials - the six pot is all about the heat build up DH super powering stuff where as the trial will be lighter and lock better...... and probs cheaper ???
Edited by manuel
I wouldnt have thought so.
I think that the KOT frames have a +20 rear disc mount, so a 160 caliper will need a 180 rotor.
Don't hold me to this though, speak to Dave or Adam at Tartybikes, they'll be able to tell you what you can and cant do.
Thats right - however you can fit a rear Mono Trial caliper and a +20 adaptor in the frame, meaning a 200mm Mono Trial rear brake could be used!
the biggest rotor you can put on kot ms2 frame is 180mm one
See above :)
180 avid beast.
Avid calipers won't fit inside the frame unfortunately.
Hope thats of use :)
Ads
