Drilled Rims
Spaz Monkey
It completely depends on the quality of the rim as to how good it is, but i'd say overall drilled rims are lighter while sacrificing some strength, and undrilled rims are heavier but more resistant to flatspots. But as i say, each rim varys vastly, e.g. the 06 echo rims flatspot like crazy, yet the drilled alex dx32 is extremely resistant to flatspots.
Ian
Drilled rims have:-
Lighter overall weight
Lighter rolling weight
Look cool
Last possibly slightly less longer
Undrilled rims have:-
Heavey overall weight
Heavy rolling weight
Can look cool too
Will last rather a long time
Key issues in all of this is rolling weight, if it's heavy and spinning it's cary some pace with it and when you us ethem ''trusted'' brake sof yours they will stop it but not as good as an undriled. it'll be mear m/s of difference but in day to daylife on cars, lorries, trains, bikes etc etc it's proven and if you look at them when out and about you'll see it in action
So yes drilled is worth it but lso carrys a bit of risk but no more of a risk than you do a 6ft drop and landing harsh and bending the rim or landing flat on your face anyway
it all depends on wich rim and how big holes you want to make.
of course, you shouldn't just drill some holes in your rim cause you feel like it
but if you masure a bit, looked up on a DX32
from 15mm holes to 22mm holes you'd save around 54% more weight, but still it'd just be a couple of ounces
all this about rotating weight, i dunno about you guys, but my trials bike aint rolling too fast anyway so.
if youre not harsh on wheels, have a heavy rim and feel that you have the time over, go for it. but i bet you wont feel any diffrence
NOOOOooo
Centruflugal force is what keep the water in a bucket thats being spun over your head in the bucket and not over you
Rolling nweight is the exess weight of thee wheel when under rotaion which will affect you in rididng and your brakes being the most important reason.
1 less weight to move
2 lees weight to stop
3 less weight to controle make sit easyer to control
NOOOOooo
...so basically you mean its lighter? :huh::blink:
I haven't read many particuarly decent responses here. Especially with the "because everyone else has them". What a ****ing lame reason to buy something.
I just got a new back wheel. I've always run D521's, but I used an Onza this time, which is 48mm wide and drilled.
The weight is probably quite similar. as this is wider so the drilled out section just compensates for the extra width. So that argument is kind of out of the window.
The main benefit and reason I went to drilled out wide rims, is to stop the tyre rolling off. If you do a lot of spinny tricks or land sideways on the wheel, it really helps with this.
My new wheel feels significantly nicer on the back wheel, but that could also be due to the new Pro II hub on there :)
i wasn't gonan say that as i'd be asked to justife it and doing it they way i have has doen so TTFN
No, no you wouldn't, you would have saved about 4 posts trying to sound clever whereas you could have just said
"They're lighter"
my god. Stop being so immature. If you don't like it sue me
EDIT: And what do you mean 'in the ranks' if you had eyes you'd see that Im validated? and you're not
End of. :P
Edited by PaRtZ
"They're lighter"
:lol:
Back on topic: Basicaly...yes.
Saves a bit of weight, and looks cool with some coloured rim tape. B)
NOOOOooo
Sorry, but the spinning wieght will have no effect when you are riding. You mean centripetal force...
Your obviously no genious, there is a difference between centrufugal and centripetal, i just dont know it!
Dont go around dissing people when you cant even read yourself.
From Lee
