10 Various Bike Pics, Mbk T1000 And Simtra St-1
AdamR28
how much are the skf bb's? and where can i get one from? i take it theyre only just sub £100 lol
Haha, the prices are pretty good actually... There's 3 models in 128mm axle, and they all fit 68 and 73mm shells. The BFR 300 (£43), then the BFR 450 (£60), and the top one is the BFR 600 (£85). The only difference is the materials, all the bearings are the same - taper needle bearing (10x load capacity of a similar weight ball bearing system) on the drive side and normal balls on the left. For example, the 300 has cromo axle and shell, whereas the 600 is full stainless steel.
IPB Image
More info here: http://www.skf.com/portal/skf/home/product...006&lang=en
Ads
ahhh cool, is there any difference in strength with the different axles?
im running a fsa platinum dh or something and at the mo it keeps coming undone on the non drive side which is annoying. its about a year and a half old so its probably time to change it anyway, do you know if the axle strength on the cheapest skf bb will be as strong or stronger as the one on my fsa?
No paint chip Waddington - thats a rock chip, haha.
Rear brake is lovely Ads :)
Sounds like you need a bit of Loctite on your left cup Pete. There's no difference in strength between the BBs, they're all super tough large diameter M12 axles, just the stainless one should last forever! The life they have designed the BBs for with XC/DH use is 10 years :o
Dave's bike hasn't changed apart from loads of scratches and a few dents in his rear rim :P --> Echo Whopper
Adam
A chain for bashers :P KHE
And for someone who likes stiff links >_<
Loving both bikes! I cant wait to see the Simtra in the flesh! i might decide i have made the wrong choice on my new frame when i see it!
To be honest i am not so keen on the multi-coloured stickered forks, they just look stoooopid :P
Looking forward to ride with you guys (Y)
