Hooking On Walls
echo v onza
well basically i have seen loads of good riders doing this and want to learn:
first question how high should the wall be to start practicing on?
secondly what technique do you use do you have to bounce the front wheel on the wall for more uplift?
any ideas, cheers Dave!
two most important tips....
SPEEED
WEIGHT FORWARDS
if you dont have enough speed, you wont have the momentum to get up
if you dont have your weigh forwards enough, you will just bounce off the wall
Start on a wall bigger than your wheelbase, when your front wheel is over the top you dont want the back wheel touching the floor, sloped walls are a LOT easier than vertical ones.
I thought a jap slap was the same beginning as a hook and then you sortof wheelswapped straight to back wheel? like hit, compress, bang straight to backwheel. rather than hit, compress, push forward and then swithc to back?
thats what i thourght a jap slap was, as for hooks, what ali said, go fast (faster than for a tap) and lean forward, and try and bend your legs under your bars to get far foward ( how vince ect do it )
Its going to be a long time until we have them dave! I reacon you could try on the massive wall near the flower bed where we normally side hope down. hmm.
Phil
SPEEED
WEIGHT FORWARDS
bounce off the wall ali what wall are we using lol i tried and hit the floor like a sack of shit lol. No bounces there lol.
WHO CARES WHAT IT IS CALLED
for hooks / japslaps / wall bangers / camel hooks, whatever you call it
SPEED, CONFIDENCE, LACK OF BACK BRAKE PULLAGE, POWER UP MIN
you have to go fast, so you carry your momentum, pulling the back break usually stops you dead so dont use it, be confident you can make it, and be a power house
I LIED BEFORE I DO USE MY BACK BRAKE. I AM A FAT IM AFRAID
